Can't Buy Sensor for Stirling-Steel CNC Conversion
Pennsy fan
Re: Can't Buy Sensor for Stirling-Steel CNC Conversion
Post by Pennsy fan » Wed Jul 16, 2014 12:30 am
I have to agree with Dickybird, a positive marker is needed to set the same place in time no matter what speed your at. An opto is what a lot lathes seem to use. I have a small emco and that's what on the spindle.
oldvan
Post by oldvan » Wed Jul 16, 2014 6:37 am
larry_g wrote:... since this sensor has a 4mm range you need something proud of the spindle by greater than 4mm to allow the flag to trigger the sensor as it passes the sensor.
If one placed the sensor 6mm from the spindle and had a 2mm lump to trigger the sensor...
hammermill
Post by hammermill » Wed Jul 16, 2014 9:47 am
you would be at the outer edge of range better to adj it for 2mm of clearance for reliability
Post by SteveHGraham » Wed Jul 16, 2014 11:40 am
I guess I'll just do what the plans say. It doesn't really matter.
larry_g
Post by larry_g » Wed Jul 16, 2014 1:50 pm
SteveHGraham wrote:I guess I'll just do what the plans say. It doesn't really matter.
Good plan. In all the years I worked with these type sensors I just treated them as a non contact switch. Some of the machines I worked with had hundreds of prox sensors on them. There were times that one had to pay attentions to setup and switching times, but most of the time its just a switch.
lg
no neat sig line
I am unique, just like everyone else.
abarski010
Post by abarski010 » Sun May 21, 2017 9:04 pm
Which sensor do I need for the CNC Conversion kit? The one equipped with PNP, NPN, Both, or do all of them work just have to wire them up correctly?
