How Do I Set Lathe up to Know Where Parts Are?
Re: How Do I Set Lathe up to Know Where Parts Are?
we are open loop here. I was going to use a mechanical switch, the same ones that are on the Bridgeport. I might need some opticals too...
- SteveHGraham
Would anyone care to give me a clue about mounting optical sensors? I can figure out the electronic part, since it appears to consist mostly of screwing wires into terminals.
Either mechnical or optical can work, with opticals being easier/cheaper to get into accurate ranges.
I used an optical on my lathe z, with 2-3 micron repeatability off the bat.
1 micron was doable, with sw filtering (using the centipede motion control engine).
A few microns are reportedly possible with mechanicals.
I used a slit type switch, with interrupter.
I then have a separate hat on top, so any chips/swarf etc. accumulate on the hat.
The interrupter has its own hat.
Theres no contact or loads, so glue, tiny screws etc. and thin-wall alu are all fine.
- SteveHGraham
Thanks. My problem right now is that there are millions of switches available, and I don't know which ones are best for my lathe. I am looking around to find out.
- DICKEYBIRD
I just checked out the website on the Centipede. Nice looking piece of kit! How long have you had it and did you need a computer engineering degree to get it functioning? I assume it reads an encoder on the spindle so it cuts threads nicely?hanermo wrote:...using the centipede motion control engine.
What do you have on the X axis for homing?
Sorry, 1 more question: do you have a build thread on the lathe somewhere? I'd love to see more details.
Milton in Tennessee
- SteveHGraham
I got another question. What is the limit on cable length for an optical switch? I don't want to have to put my controller right next to the lathe.
30 feet or you may pick up noise. I think some suggest shielded wiring anyway. These are usually "normally closed" meaning there should be logic voltage levels.
