The Home Machinist!
It is currently Sat May 25, 2013 10:30 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3, 4  Next
Author Message
PostPosted: Wed Mar 05, 2008 1:19 pm
Offline
HI,
We are starting a foundry and needed a burner to warm things up. Found a plan at Lionels Metalcating page and built it. Made it an in-line versis his 90 degree one. Nice blue flame.
Next up is a cart for the furnace and a handle to lift the lid.
Tom C.
_________________
tom_at_srclry_com
Lost somewhere in Michigan!
Top
 Profile
 Post subject: cart next
PostPosted: Wed Mar 19, 2008 11:33 am
Offline
The cart is almost done. Needs lid installed and over center stop welded on. Next up is ingot molds and a pot to melt aluminum in.
Tom C.
_________________
tom_at_srclry_com
Top
 Profile
 Post subject:
PostPosted: Thu Mar 27, 2008 3:42 pm
Offline
We made some crucibles by welding a plate on a pipe and heating and bending a lip with a big hammer. Bolts and a pouring tab were welded in to easy the lifting and tipping. Then I made some ingot molds to hold the metal till it cools.
Tom C.
_________________
tom_at_srclry_com
Top
 Profile
 Post subject:
PostPosted: Fri Mar 28, 2008 4:52 am
Offline
tomc, DANGER < DANGER WILL ROBINSON! ok, oil your molds, after you blast them free of rust. DO NOT pour molten aluminum into the molds I see. They will POP and Explode molten aluminum as you pig out. I have the same forms but they must be FREE FROM IRON RUST, or they will pop and spray aluminum when poured. This is the same system I use, but HEAT the molds to prevent water from condensing on the molds and remove oxides as the AL will react and pop the molds splattering the shop. Ask me how I know. ( GRIN)..
Ya, you got it goin, just do it right to be safe.
Good work, I bid you peace.
_________________
Big Dave
Be Alert! The world needs more Lerts.
Top
 Profile
 Post subject:
PostPosted: Fri Mar 28, 2008 11:57 am
Offline
Thanks Big Dave. We will watch that closely.
_________________
tom_at_srclry_com
Top
 Profile
 Post subject:
PostPosted: Thu Apr 03, 2008 9:31 am
Offline
We fired up the furnace to drive out the moisture. A few pics.
Tom C.
_________________
tom_at_srclry_com
Top
 Profile
 Post subject: Refractory
PostPosted: Sun Apr 06, 2008 6:34 pm
Offline
What did you use for refractory?
Top
 Profile
 Post subject:
PostPosted: Sun Apr 06, 2008 9:32 pm
Offline
We got the body donated so only made the lid. I bought refractory cement from a brick dealer.
Tom C.
_________________
tom_at_srclry_com
Top
 Profile
 Post subject:
PostPosted: Tue Jul 08, 2008 2:26 pm
Offline
Melting aluminum is fun! Sounds like a good topic. Anyhow, we are busy making ingots from our scrap. Tried a pour to a mold but I don't like the outcome. I am looking for a finer grade as I got sand blasting and is to rough.
Melted some Morton's lite salt for a flux to try. That is in the big saucer.
Tom C.
_________________
tom_at_srclry_com
Top
 Profile
 Post subject:
PostPosted: Wed Aug 06, 2008 12:24 pm
Offline
Hi,
Now that we have our melting down, We need a beter way to mix our sand. We are starting a mueller. It is sitting on the frame I welded up with the 83 to one gear box we found on Ebay. Below is the tub with the wheel blanks in it, the motor and center support. More to follow as it comes along
Tom C.
_________________
tom_at_srclry_com
Top
 Profile
 Post subject:
PostPosted: Wed Aug 06, 2008 5:27 pm
Offline
Keep it up Tom,I can't wait to see your castings. Andy
Top
 Profile
 Post subject:
PostPosted: Mon Sep 01, 2008 2:07 pm
Offline
For fluxing aluminum, use HTH pool tablets broken with a hammer into sugar cube size lumps, wrap powder and small pieces in foil, use an infuser cup to add to the melt, skim dross, pour.
Make an infuser cup by making a cup shaped disc with a few 1/4 inch (5/16) holes drilled in a pattern, and weld it to a rod of about 3/8 to 7/16, maybe some 30 inches long. A packet is made with the additions of aluminum foil wrapped onto the edges, and the works plunged into the melt and spin/swished to flux the melt right before pouring. Be decisive with your moves and only take a second or two to move the melt and stand back, away from the fumes.
Warning: the chlorine gas is small but not good for your health so stay upwind and in a vented area. ( a box fan serves for me keeping the breeze going as I bake in the love of a melt.)
_________________
Big Dave
Top
 Profile
Who is online
Users browsing this forum: No registered users and 0 guests
Search for:
Jump to:
