That seems to be the consensus. I really want to minimize the maintenance on this track.charlie bill wrote:Harlock: I believe you best bet is to use steel rail on plastic ties, having laid a bit of this track, you will have less maintaince. Any other track is a real headache.
The space is so small it cannot accomodate anything larger than 50', and due to obstructions one end of the loop will have two segments of 40' radius. So we will be living within those limitations. People will just not be able to bring super long rigid wheelbase engines. This is more in the class of a home track due to the space available. Blind drivers would helpcharlie bill wrote:These are just suggestions. A 75' radius, will handle any engine.
Mojave, CA. (90 miles NE of Los Angeles)charlie bill wrote:If I may ask where are you located? I may be able to find out some prices which may be high and then there is the shipping.
Charlie
I will probably use the plastic tarp since, while it is in the desert, there may be some spill over from time to time from a landscaped area that is watered.
--Mike
