New member
New member
I am currently building an Allen Mogul. Rolling chassis ,siderods, and cylinders completed. Now working on brake rigging, and soon to start the valve gear. I am trying to stay as prototypical as possible, so I have made many changes in the Harper draawings. For instance the flame cut frame has a slope for the forward sloping firebox. Have just completed a fabricated brake bracket consisting of 8 silver soldered parts each.
I have been unable to find a bilders plate on either the prototype erection drawings, or original photographs. Does anyone have a photo or diagram which details a Rhode Island Locomotive builders plate or even its location?
Wayne
Wayne
- SZuiderveen
Re: New member
wayneheggan wrote: Does anyone have a photo or diagram which details a Rhode Island Locomotive builders plate or even its location?
Wayne
hi: building the 10 Wheeler here.
Hi,
I'm in the process of building the Allen 10 Wheeler up here in CT. The 10 Wheeler and Mogul share a lot of common parts.
Rob
Rob
Wayne,
Since you are in the brake rigging department on you locomotive, you might want to consider a minor change. The Allen brakes and many other model locomotive brake systems were designed without equalization in the linkage for years. Many of the Little Engines and Railroad Supply designs seemed to just use the same basic style of brake systems all without equalization in the linkage.
It is a simple task to do the math to change the locations of a few holes and a slightly longer piece of material in a few places to achieve prototypical equalization and more even braking in your model.
The first brake beam needs a 2:1 lever and the second brake beam needs a 1:1 lever if things are to be correct.
Hope you are not too far along to make this minor change. I had my RRSC mogul brake system all completed before I realized how poor the engineering was. I went back and changed the entire system saving only what I could and making quite a few new parts. In the end, I had fewer parts and a much smoother operating brake linkage system.
Robert
Robert
brake rigging
could you send me a simple diagram of the modified brake rigging? I dont know where you place these "levers"
Wayne
Wayne
drawings of riggin'
I will post / send you a drawing if you like.
personal e-mail will make it possible
- makinsmoke
New member
Me too, Bill!
Thanks,
Brian
Thanks,
Brian
Re: New member
We own Warren's Mogul. The brake rigging is slightly off. When you apply the brakes one brake sets while the other releases. Then when you release the brakes they switch and one is set and other is released. Could you please email brake rigging photos to mike@livesteamers.org Any help would be great. We hope to have her up and running by January.
Mike
Mike
Re: New member - Equalized brake rigging
Here (hopefully) are the drawings I used to change my Allen Ten Wheeler brake rigging to fully equalized. They work much better now.
The last drawing shows the general arrangement for 4 axles. Still a good illustration for equalizing.
Re: New member
Here's how the prototype does it
