Mill Enclosure
This forum is dedicated to those Hobbyists Interested in CNC machining in their home shops. (Digital Read Outs are also topical, as is CAD/CAM as it relates to CNC)
suissehorology
Mill Enclosure
Post by suissehorology » Sat Aug 30, 2008 3:36 am
I am purchasing a Sherline mill to go with my taig lathe. Can anyone direct me to photos of mill enclosures so that I can get some ideas. Thank you. Rob
Rob
dang2
Post by dang2 » Mon Sep 15, 2008 12:59 am
Search Cnczone for "mill enclosure". There are 3 or 4 good examples there.
For a sherline, you might only need a cement trough from Home Depot and plexiglass cage for the coolant.
kapullen
Post by kapullen » Fri Oct 31, 2008 6:50 am
suisse...
Here is an enclosure I designed for the machines at work (the blue thing).
The front swings down, or will come off completely for cleaning, and loading the vise.
These were bent up but a bit of aluminum sheet, angle, and pop rivets will
do the job.
Kap
Fadal Turn, Fadal Vmc 15, Prototrak 16 x 30 Cnc Lathe, Pratt and Whitney 16 x 54 lathe, Pratt and Whitney Vertical Shaper, G & E 16" Shaper, B & O Electric turret lathe, 36" Doall band saw,
Enco B.P. Clone, Bridgeport CNC Mill, Delta 12" Surface Grinder.
Post by Harold_V » Fri Oct 31, 2008 2:44 pm
Very nice, Kap. Every bit as nice as the enclosure offered by HAAS for their toolroom CNC mill------for $800!
