Doing some grease/dirt removal this morning with Simple Green, I discovered that I have a taper attachment hiding under a sheet metal cover (!?) It's missing the way clamp and looks rusty from underneath, but hopefully is salvageable.
Agh, the more I get to know you, the less I like you....
Congrats on the find, and I hope you can salvage it.
I've had good luck derusting stuff with inexpensive Phosphoric Acid bought at Home Depot. Look for "Concrete Etch". I dilute it about between 3:1 and 5:1 depending on what I'm doing and how bad the part is. Use normal precautions, acid into the water, Nitrile gloves, and eye protection. But Phos Acid is really pretty mild stuff (it's in Coke and many other foods). Stuff is amazing, and often doesn't even remove paint. In your case, it's going to be tougher to use on the big pieces, I usually submerge in the solution. But like Evapo-Rust (different process), you can wet towels and lay in place, then keep wetting and applying.
Have you had power to it and checked to see if everything operates yet?
Not yet. First order of business is to get it off the trailer. Looking for local wrecker/forklift/bobcat at a reasonable price.
Then I'll need to finish wiring the RPC. My electrician friend supposedly has the extra parts I need (cutoff switch, 3ph outlet and plug), but has to find the time to come over.
Another suggestion would be to order a 12 X 12" sheet of 1/4" thick Linnen Phenolic from MSC, McMaster Carr etc. and make some scrapers. You can cut them to any size and shape and put an edge on them with a belt sander. Tape up the handle for comfort and you're good to go. They hold an edge really well and being of resin and fabric composition they won't scratch critical surfaces.
A drop of motor oil, a brass tooth brush and elbo grease for rusty areas. maybe a little cup brush on a drill, but it is more likely to polish off the rust and clean to bare metal than sanding or chopping at the crud. The oil leaves rust proofing and allows the dust to drool together for wiping down.
I dont like water solvent/acid based things, they are easy but have a problem with Hideout that can bite ya. If you think dunk the gunk, then disassemble and go for it. The gloves are on so to speak, but work fast, dont delay, and get it done and wiped off.
