What cutoff blade for my phase II AXA tool holder.
Moderators: Harold_V, GlennW
737mechanic
Post by 737mechanic » Sat Jun 13, 2009 11:20 am
I just got a phase II AXA tool holder and after looking on enco's website they list tons of cutoff blades so now I am lost as to what I should get. What are all these industry standard numbers and what do you guys recommend for a cutoff blade.
The holder holds 1/2 in. blades.
Leroyt
Post by Leroyt » Sat Jun 13, 2009 11:45 am
I use the "T" type listed here. Set the blade heigth to center and your good to go.
http://www.use-enco.com/CGI/INPDFF?PMPA ... M=397-7032
Leroy.................
GlennW
Post by GlennW » Sat Jun 13, 2009 12:13 pm
I slide a strip of brass shim stock between the tool holder and the lower portion of the blade to compensate for the "T" and square ithe blade up vertically. 'Cause I'm too lazy to do it properly and move my vise to relieve the upper area of the tool holder groove.
Edit: (Another) Typo
Jose Rivera
Post by Jose Rivera » Sat Jun 13, 2009 12:53 pm
I had to do the same with mine, but I am using a .040" wide blade I bought from littlemachineshop.com
Black_Moons
Post by Black_Moons » Sat Jun 13, 2009 1:35 pm
I like the shim idea! I guess messure the top and bottom of blade and devide by half and go look in my feeler gage set. For wedge type blades I guess you could messure top and half way up and cut the feeler to half the blade height.
GlennW
Post by GlennW » Sat Jun 13, 2009 2:48 pm
Black_Moons wrote:I like the shim idea! I guess messure the top and bottom of blade and devide by half and go look in my feeler gage set.
Or thicker!
Frank Ford
Post by Frank Ford » Sat Jun 13, 2009 3:52 pm
I have an Aloris cutoff holder, and it has an angled slot to accommodate the T-blade nicely.
But, my Chinese holder didn't so I simply milled a relief groove:
Here they are together:
Cheers,
Frank Ford
coal miner
Post by coal miner » Sat Jun 13, 2009 8:46 pm
Thanks for the tip , Frank . I did same thing to my holder after seeing your post in the subject some time ago . Works great ! 737 mechanic On the Craftsman and the Jet 14 x40 I just use HSS . I always touch them up w/ a stone , medium then fine , before using . Being square to the part is critical , sometimes I will use a test indicator to make sure everything is up to snuff . Maybe I'm just lucky , but not had to many problems parting off. Larger diam , as in 2.5 on up some times tends to go convex by a thou. or so , I think it might be due to the edge on the blade not being right on the money to sq. Got the magnifying glass out the last time and it seemed to help . Maybe I'm a little anal about this but once the blade whizzs by your head or the Craftsman slips belts , you try to get everything right . Parted off a piece of 2.750 Al the other day , 230 rpm and .0016 feed and used the power feed , very smooth cut.
The more I learn , The more I don't know !
JimGlass
Post by JimGlass » Mon Jun 15, 2009 5:53 pm
I use the "T" type blades in my AXA holder.
I have found the .077 wide "T" blades work very well in my
13" JET lathe. Narrower blades like .062 snap off after going so deep.
Wider blades seem to chatter then snap off.
Been using the same .077 wide blade for for well over five years. I do not remember where I got the blade.
Anyone else experience this??
Jim
www.outbackmachineshop.com
BadDog
Post by BadDog » Mon Jun 15, 2009 6:20 pm
Regarding parallelism when parting...
For all but the deepest parting (beyond 1/2" max DOC before separation) I just use the thin leg of a machinists square placed on the face of my chuck. I then put the parting tool *blade* against the opposite (parallel) side of the leg and then lock the tool post. One last verification that it is parallel (no wiggle in the square pinched lightly between) and I'm off and parting. Fast and easy...
If the DOC is approaching or exceeding (depending on material) I actually dial it in to be sure. But for both my HSS parting and my inserted Sandvik parting tool, the parallel works well for most all my needs and I've not yet seen a problem.
SteveHGraham
Post by SteveHGraham » Mon Jun 15, 2009 6:38 pm
"Relief groove"?
Uh oh.
lakeside53
Post by lakeside53 » Mon Jun 15, 2009 7:24 pm
Hey, you just bought a mill. Now you have a use for it :lol:
