** How do You Deal With Swapping Lathe Tools in Holders?
rstreift
Re: How do You Deal With Swapping Lathe Tools in Holders?
Post by rstreift » Fri Jun 19, 2009 9:00 pm
I rack the BXAs using dowel rods in plywood treated with Linseed Oil.
The shaper tool is not used on the lathes. :-)
- Reed
BXA board
Black_Moons
Post by Black_Moons » Fri Jun 19, 2009 11:27 pm
Weird, square boring bars!
Very nice looking setup harold. I wonder if a similar setup could be easily made with a mill+rotary table.
I like the wooden holders myself.. im kinda worryed those L brackets might score the surface of the dovetail and that might score the toolpost. I guess if they are aluminum its likey OK, but steel id worry about..
lakeside53
Post by lakeside53 » Sat Jun 20, 2009 10:24 am
Wow.. Count them!
I thought I'd scored with 12 Dorian toolpost holders on my newly aquired lathe... but.. :wink:
Does anyone know if the CDCO/Phase2 type CXA holders fit the wedge Dorian Tool posts? If i need more,,, I'm not spending $89-$140 each on the OEM..
Mark Hockett
Post by Mark Hockett » Sat Jun 20, 2009 11:37 am
Andy,
The Aloris type holders will fit on the Dorian post.
Mark Hockett
