I want to Make this..
mike71
Post by mike71 » Fri Jul 17, 2009 11:31 am
I want to make this, so I can turn balls and or curved parts...
I think I can just look at It and build it but if anyone here has any ideas or opinions please let me hear them...
mike71
Post by mike71 » Fri Jul 17, 2009 11:32 am
In use.
JimGlass
Post by JimGlass » Fri Jul 17, 2009 11:53 am
I like your design. Looks more rigid than the one I made and your radius adjustment is better.
The one I made.
I made it 10 years ago and have only used it twice.
Jim
www.outbackmachineshop.com
david5605
Post by david5605 » Fri Jul 17, 2009 11:54 am
Here you go...
http://www.projectsinmetal.com/free-met ... athe-mill/
There is a link to the plans a couple of lines after the video.
Black_Moons
Post by Black_Moons » Fri Jul 17, 2009 1:37 pm
How did you make the C's? they kinda appear to be one chunk of metal.
mike71
Post by mike71 » Fri Jul 17, 2009 4:17 pm
Thanks for the link, its now saved, I gots new reading now.
Lykle
over the top ball turner
Post by Lykle » Sat Jul 18, 2009 3:11 am
I just designed this puppy after seeing a version of this in a kit.
It basically is a boring head on it's side with a handle to rotate.
I made some stops, so that the movement is repeatable.
In this case I used a round indexable bit, but designed a triangular holder as well.
My tool post is the black thing, I use a cylinder of 1,5 inch as a tool post and all my tool holders are just chucks of Alu with a hole in em.
I am building this this as we "speak"
Lykle
Designing for the fun of it.
steamin10
Post by steamin10 » Sat Jul 18, 2009 11:12 am
Not to throw rocks, but the other two designs use the center pivot and the distnace to the cutter, to determine the radias of the ball. ( sphere shape).
I dont see where your tool will have such repeatability.
I have used the C shaped former before, and it is slick. Feeding in from the tailstock alows succesive cuts to fully form the ball front. Carriage past to the stem and work the backside until the tool meets the center axis and you are done. Or, doing the base, and reducing the front to a repeatable dimension to a stop works too.
I never thought to make such a tank turret tool, that would work the same way. What is the drawback of such a small turret? When I became aquanted with the ball former, our shop had 2 sizes.
Since we made bolts, the tool guys were always making pan head tools, with this tool cutting concave forming dies, of infinit sizes and radii.
steamin10
Post by steamin10 » Sat Jul 18, 2009 2:41 pm
Oohh, Duh, I had it 90 off in my mind. I came back looked again, and it is clear now. Thanks.
Jose Rivera
Post by Jose Rivera » Sat Jul 18, 2009 8:06 pm
I am in the process of finishing my own tool based on the first concept but of my own design.
As soon as finish it I will posting a link for the pictures.
