DRO installation
DRO installation
I picked up a 3 axis DRO @ Grizzly today. My big conundrum is installing the X axis on the front of the table without losing the powered feed limiter and the table locks. To keep the limit switch would require spacers a little over an inch and a half long. I would like to use the scale cover which will require the scale to be spaced out no more than 1/4 to 3/8 inch. If I hang things too low the table locks can't be used.
Dennis
Thermal Arc 185-TS
Millermatic Challenger 172
Victor O/A
Atlas Craftsman 12 by 24 Lathe
Esab PCM-875
Wholesale Tool Mill-Drill
Thermal Arc 185-TS
Victor O/A
Esab PCM-875
DRO
Tailshaft,
For the reasons that you mentioned most mills have the scale mounted on the back side of the table. The drawback is that it limits the amount of travel on a small mill! I have a small mill and wanted to put a DRO on it as well but I have not been able to resolve the travel loss issue or mounting the scale on the front and lossing the power feed stops. I suppose using some long spacers may be the answer if it has to go on the front.
Dave C.
Dave C.
I have a rf45 clone and I mounted the x scale on the front. I also wanted to keep the limit switch and the table locks accessable.
Here was my approach. Hopefully pictures follow.
Mounted a piece of aluminum angle on the front of the table. this will be the scales main protection and also hold the rubber flap on the front (see picture).
Mounted the x scale with the aluminum angle between the scale and the table.
Mounted aluminum blocks on each end of the aluminum angle to hold limit switch bars. Fastened them through the angle to the front x dovetail slot too.
Mounted the scale head to the mill with appropriate aluminum angle.
Mounted limit switch in front of read head. On same bracket as read head.
Clamped rubber membrane to front underside of angle.
Then....Had to make an extension piece for the Y table handwheel to space it out about 1-1/2". Otherwise the new setup ran in to it if the Y was cranked out to its limit.
The bracket shown was sort of designed on the fly so it looks sort of hacked (to say the least).
I'm happy with the end result but sometimes designing as you go can be frustrating.
The limiting takes place on the Y axis as the table travels almost to the column base. You lose about an inch and a half with the supplied aluminum cover. This drops the Y travel to 6 inches.gmann109 wrote:The X-Axis is best installed on the rear of the table. I've not seen one on the front, although I guess some people mount them there.
An X-axis scale of the proper length (longer than actual travel) won't limit your travel at all.
Dennis
Thermal Arc 185-TS
Victor O/A
Esab PCM-875
Thermal Arc 185-TS
Victor O/A
Esab PCM-875
Yes, I see what you mean. Well, you have to make allowances for different types of machines.tailshaft56 wrote:The limiting takes place on the Y axis as the table travels almost to the column base. You lose about an inch and a half with the supplied aluminum cover. This drops the Y travel to 6 inches.gmann109 wrote:The X-Axis is best installed on the rear of the table. I've not seen one on the front, although I guess some people mount them there.
Good luck!
David 5605
Thanks for sharing your setup. I was thinking of spacing the scale out and reworking the limit switch so that it would be about half as thick as the stock switch. The drawback is it would likely entail using microswitches and might require a lowvoltage supply and the use of a couple of relays.
Seems like your setup is more elegant and may be the way to go.
Dennis
Thermal Arc 185-TS
Victor O/A
Esab PCM-875
Thermal Arc 185-TS
Victor O/A
Esab PCM-875
Have you any info regarding the age and origin of your Craftsman/Atlas lathe? I ordered mine when I was 15, long, long ago. It is the 24" centers version, w/o quick-change gears, as money was in very short supply. The motor I chose to go with it was a Craftman ball bearing 1/2 HP. In all those years, the motor still serves well, having had new bearings installed once. I am now on my 3rd. or 4th. on-off switch. This machine has made lirterally thousands of parts during it's 50+ year life.......tailshaft56 wrote:David 5605
CB&Q
One can derive far more personal pleasure and reward from observing Mother Nature's living things instead of Humanity's Madness.....
Those Craftsman motors were excellent. I have a Craftsman Drill Press that my father bought new in 1959. It had a 1/2 hp motor that lasted 40 years until about 1999 when I had to replace it since it began to burn up. That's pretty good service. I still use the drill press nearly every day.CB&Q wrote:Have you any info regarding the age and origin of your Craftsman/Atlas lathe? I ordered mine when I was 15, long, long ago. It is the 24" centers version, w/o quick-change gears, as money was in very short supply. The motor I chose to go with it was a Craftman ball bearing 1/2 HP. In all those years, the motor still serves well, having had new bearings installed once. I am now on my 3rd. or 4th. on-off switch. This machine has made lirterally thousands of parts during it's 50+ year life.......tailshaft56 wrote:David 5605
CB&Q
In the old days when they were American made, Craftsman tools were as good as or better than anything on the market.
I don't know the history of mine. I was thinking of a 3 in 1 but this came along. Sort of lucked into it. I was getting an oil change and picked up a copy of the big nickel and saw the add. I guess the God of machine tools was smiling that day..as I also happened to have the money to buy it. It was a 12 X 24. Keith from Kansas called me one day about getting picking up a couple of used engravers built on an Atlas 36" lathe bed and cabinet. I now have a 12 X 36 on a cherry bed. Just need to make a longer lead screw someday.
Dennis
Thermal Arc 185-TS
Victor O/A
Esab PCM-875
Thermal Arc 185-TS
Victor O/A
Esab PCM-875
The X axis is complete. The cover is two pieces of Al. angle tigged together. I still need to fabricate the bracket for the power feed limit switch. The stops are going to be blocks that clamp to the outboard piece of angle. Hopefully the linear bearings will be here by next week so I can do the z axis then all will be right with the world. ( At least the part of it I can control.)
Dennis
Thermal Arc 185-TS
Victor O/A
Esab PCM-875
Thermal Arc 185-TS
Victor O/A
Esab PCM-875
