HELP: improving lathe carriage accuracy??
Moderators: Harold_V, GlennW
Hank.W.E
Post by Hank.W.E » Tue Nov 17, 2009 12:39 pm
I mounted a dial indicator in my chuck, and checked the alignment of the TS. As predicted, the centre was off by .005 (L-R). I adjusted it, and now it's centered (LR)
I made a troubling discovery during this task.
The TS centre is slightly higher than it should be (roughly .005)
How big of a problem is this?
Russ Hanscom
Post by Russ Hanscom » Tue Nov 17, 2009 1:23 pm
Here is an easy way to monitor tailstock offset and to see how much it moves when you want to move it. In this case, the indicator mount is screwed to the tail stock base and the indicator tip is touching a piece screwed to the upper part of the tailstock. A thumbscrew holds the indicator in the mount.
SteveM
Post by SteveM » Tue Nov 17, 2009 1:39 pm
Hank.W.E wrote:The TS centre is slightly higher than it should be (roughly .005)
I can't do the math off the top of my head, but it's a lot less than if the TS is 5 thou forward or back.
Think about having an indicator on the side of a round workpeice and then moving it up 5 thou. It will move only slightly in.
Many lathe manufacturers make it a little high to account for wear, although 5 thou seems like quite a bit. Maybe there are shims in there you could remove?
What was the result in turning after adjusting the tailstock?
Russ - neat tool. Maybe I should make one of those for one of the spare indicators I have lying around.
Russ Hanscom
Post by Russ Hanscom » Tue Nov 17, 2009 2:06 pm
Hank,
The error from vertical offset gets worse with smaller diameters and when the tool is above or below the centerline. It is my understanding that new lathes usually come with the tailstock set .0005 high to allow for wear; .005 seems like too much.
You might remove the tailstock from the lathe and separate the upper and lower sections. Check for debris and dings. If it is still too high after you reassemble it, might consider having one of the pieces ground down with a surface grinder until you get to the desired slightly high dimension.
GlennW
Post by GlennW » Tue Nov 17, 2009 2:09 pm
How was the indicator supported and what type of indicator?
An indicator used horizontally is subject to error depending on the setup.
Gravity you know.
It would make the quill appear high.
SteveM
Post by SteveM » Tue Nov 17, 2009 3:22 pm
Glenn Wegman wrote:Gravity you know.
Gravity, it's not just a good idea, it's the law!
You could check the gravity effect by chucking up a bar, mounting the indicator on the chuck, indicating on the bar and rotating the chuck.
GlennW
Post by GlennW » Tue Nov 17, 2009 3:30 pm
Re-post from another thread:
DTI's on arms and sag error when used horizontally:
My feet are on the ground!
Vertical:
Inverted:
Gotta be careful what they are attached to and how you use them or you may just re-discover gravity!
GlennW
Post by GlennW » Tue Nov 17, 2009 3:37 pm
A CoAx may actually be a decent choice for sweeping a tailstock bore as it is subject to very little error when used horizontally with a short arm..
dly31
Post by dly31 » Tue Nov 17, 2009 9:25 pm
Before you do anything not reversible you might want to do a lot more checking to see whether the headstock and/or tailstock are correctly aligned so they are parallel to the ways in both planes. Otherwise you may wind up creating two or more compensating errors instead of getting it better.
Don Young
Rich_Carlstedt
Post by Rich_Carlstedt » Tue Nov 17, 2009 10:24 pm
As Lathes wear in industry, the problem you encounted is seen quite often.
The normal procedure is to not worry about whether the tailstock is alligned or not.
You want the lathe to make a good part, that is the objective !
There are numerous reasons ( as pointed out by some here) for the Lathe not cutting to your expectations. You can spend hours trying to peak each expectation, and still never produce a good part
Chuck a piece of stockup using the tail stock center you prefer, and make a cut.
Mike the diameters at each end.
Put an indicator on the tailstock,set it to zero, and then move the tailstock one half of the offset found.
Take another cut, and adjust again, and you will have a excellent chance of hitting your target.
Centers, leveling, part weight, diameter, tool height, bearing errors ---all have input.
The object is to make a good part.
Your comment about the TS being too high should not affect a 1" OD part, but will have huge impact on a .0625 diameter part.
Each factor has effects based on other factors.
Rich
The normal (or "factory") setting for tailstocks is .001 offset towards the operator, and .001 High. This handles most cutting loads encountered----but not all !
Hank.W.E
Post by Hank.W.E » Wed Nov 18, 2009 12:06 am
I just got in from the shop, and yes, I did re-discovered gravity with my dial indicator. I really wasted a large amount of time doing this.
I took apart the tailstock, and found the reason for the height problem.
When the lathe was powdercoated, paint and powder coating got into places where they shouldn't be (mate surfaces of the TS). I cleaned all this up, and it's much better (according to a dial indicator with the effects of gravity).
Another thing I discovered was the rod that accepts the set screws was turned so the flats were not parallel with the lathe ways.
I'm going to roughly set the centre tommorow, and try Rich's suggestion: Turn bar stock, mike each end, set indicator on TS, and move to adjust for error. I'll do this untill it works.
Thanks for everything! I'll post again to let you know how it goes.
Hank.W.E
Post by Hank.W.E » Wed Nov 18, 2009 8:40 am
BTW, this is where I learned to tram a tailstock with a dial indicator:
http://www.finelinehair.com/home/9x20_t ... k_tramming
