It's generally used for comparing against some "master", often a gage block stack (or Master Height gage (often referred to as a "Cadillac"). Using the master, you set (usually zero) the DTI using the height gage adjust. Then you move to the object of interest. If it has the same vertical size, you get the same reading on the DTI. If not, baring cosine error, it tells you how far you are off. Better yet, use the height gage to achieve the desired reading, and you know your difference. Can also be used to check other things with creative configuration, and a surface gage can also be used similarly, but is actually even more flexible, though not able to take direct readings as can be done in vertical measure with a height gage.
