The version I have is Windows version 3.01 copy write 1985- 1996 by ISMI.
It will let you draw to size and print to scale or go the other way too. I all ready knew AutoCAD some so tha tmay hav ehelpped the pick up.
The thing I like best about it, other than i paid like $30 bucks retail for it is with todays printers, you get really acurate pint outs, and can even print on trasparency film for templates.
I got dial crank mills and often will put a template on top of work to show me if I turned the right number cranks turns. Saves a lot layout time and erros.
For one or two off radial bolt paterns, I jus due them on the cad and then X & Y dimesion, to save time setting up the rotary table.
For non critical shapes in sheet stock, glue a print on with wood glue, saw and sand, then soak the print and glue off in warm water.
Rob
Help with a most vexing problem
Qcad, anyone? It's a GPL freebe for Windows, Mac & Linux. http://www.ribbonsoft.com/qcad.html
Seems to work okay, but I've no other experience with other CAD systems. I've used this one to design homemade gearcutters, but that's it. I keep reaching for the scratch pads instead...
Re: Help with a most vexing problem
Tried Autosketch 7 and was able to figure it out.psient wrote:Hi all:
I'm moving forward with my efforts.
What I need from someone is a &%$# 2D drawing software program that will let me do what I used to do with my ruler and graph paper.
I'd like to have a software that makes the task automated to some extent.
For instance:
1. scale the drawing to the scale I specify
2. let me draw shapes and lines
3. interpolate the dimensions of each component of the drawing
4. place dimension lines, markers, and legs on the scale drawing
I know I'm missing something here. Anyone able to help?
Thanks,
Jon
Bought an OEM version of Autosketch 9 for 70 bucks. What I wanted.
Thanks for the comments all!!!
JON
I would have to vote for Design CAD. Cost about a $100. I have used it for years and not to hard to learn. I have tried to learn Auto CAD and found it to be a pain. The elitist drafters will swear by Auto CAD but most of those folks have gone to school to learn Auto CAD. For a hobby shop, like mine, look at Design CAD.
There is Solid Edge from Siemens its free. http://www.plm.automation.siemens.com/e ... ndex.shtml I have it installed but have not used it. I play with Turbocad. I agree with the comments that say CAD has a steep learning curve. Let us know what program you decide on and how you progress.
