Built a guide setup for my new grizzly 8" plate shear.
csspecs
Post by csspecs » Sun Jan 31, 2010 1:29 am
I do a lot of sheet metal work, but I am finding that my large step shear is rather hard to use to make the hundreds of small cuts I normally do at a time.
I've been thinking about getting one of those little grizzly plate shears for almost a year and I finally gave in about two weeks ago. Glad I did.
Once I got the unit in my hands I found two glaring problems with how I planned to use it, first it had no guide for square cutting, and it had no back gauge for repeating the same cuts.. Still I loved how well it cut the thin metal, almost no effort at all needed. So I decided to make a table to mount it to and guides and the like. I have no idea how you would use it as supplied, just off pencil lines or something?
I figured a few of you guys may have use for something like this so I took pictures and videos of it being built. I just finsihed the back gauge about two hours ago, seems to hold true to about .0005 I don't have a large enough mic to test so I only have calipers to check. Its well within my needs for perfection.
Videos
Part 1
http://www.youtube.com/watch?v=eapHNsBIpR4
part 2
http://www.youtube.com/watch?v=d0-H9VtsIIs
Jose Rivera
Post by Jose Rivera » Sun Jan 31, 2010 4:53 pm
The picture and the videos are to dark to notice details.
Can you post a picture that shown more area ?
whateg0
Post by whateg0 » Sun Jan 31, 2010 5:34 pm
That type of shear has been used for hand-guided cuts when I've seen it. I made one awhile back for cutting aluminum sheet. I've thought about making some attachments like the backstop and a square edge, but for what it was intended they wouldn't work. Where this type of shear excels is in cutting long strips, or longer cuts that would require a very long blade to be made all at once. Think of a pair of scissors cutting wrapping paper.
Dave
csspecs
Post by csspecs » Sun Jan 31, 2010 7:07 pm
Yeah I'll grab a camera with a flash and take a few more. Be a few hours.
I have a 36 inch step shear, and I have my metal sheared to 24 inches wide or smaller before I pick it up. 5.00 a cut is pretty cheap in my mind. I also have one of those disk shears (looks like a big can opener) that can do long stuff and curves.
I made the shear table because I'll have a 10 foot long 3 inch wide strip that I need to cut into 1 inch wide parts. And the step shear is a heck of a work out to use like that.
