Wheel turning service
Hi all,
I just recently added a 14" Reed Prentice lathe to my shop. If there's anybody out there that needs drivers or tires turned up to 14" (The lathe will swing 16 1/2"); send me a sketch or drawing and I'll quote them for you.
References available.
I can run other types of parts as well.
awpliamloc at verizon dot net
Thanks,
Andy Pullen
Thanks,
Andy Pullen
Here are some drivers ready for the bead blaster prior to painting and tread turning....Crankpin holes and keyways to be done as well.
A photo of the back side of a wheel from the same order in the lathe.
Here's a flyweight being machined for a Roll Models 2-6-2.
Bump
Lathe is open...Any kind of lathe work....Smokeboxes, wheels, tires, flyweights, axles, journal boxes, etc...
Andy Pullen
Andy Pullen
Thank you for the kind words, Jon...
I take my time and am not trying to get "rich" doing this. If I can help somebody out and make a little "mad money" or trade something in the process, I'm happy.
Making wheels is fun for me....You gotta like what you're doing....
Andy Pullen
Andy Pullen
Thanks John,
I've got 16 more blanks cut for the other pair of Fs....I ought to have them for you at CF next month...
Andy
Andy
Bump
Here are some Allen Models Mogul drivers that I'm waiting on journal boxes for from the customer. They will get bead blasted again to clean them up before shipping.
Andy Pullen
Andy Pullen
Re: Wheel turning service
Here is an ashpan I made for another client. Sheet metal isn't exactly my strength and I'm not a welder, but I can make stuff like this as well. I'll be posting pics of castellated nuts for crankpins in a day or so....
awpliamloc at verizon dot net is my home email. Change the "at" to @ and the "dot" to .
410-652-2850 for my cell. When I'm at my day job (6:30am eastern time to 4:00pm); the cell doesn't work in the building, so leave a message....I'll call you back.
Thank you,
Andy Pullen
Thank you,
Andy Pullen
