mechanicalmagic wrote:
Marty_Escarcega wrote:
I think we will remove the subsilver style permanently when new ones are installed. It cause much grief for some users who didn't readily change it.
Marty,
I can't seem to find the button to change the styles.
Dave,
The quote, above, should read in reverse. Because the prosilver board type was causing problems for folks with older operating systems, subsilver2 has been made the default display, due in part to some readers not being able to access their control panel in order to make a change. As a result, readers do not have an option of board display type right now, thus the button is not displayed.
When other options are once again offered, the button will return.
So then, for the record, the board display in use currently is subsilver2.
Hope this helps.
