PapaLion wrote:
So, I believe a solution might be to to place a fitting in the 1" pipe line just before each entrance and run a short pipe in for the fuel. What you would end up with is a dual Waste oil Burner setup, one burner for each entrance.
Thoughts?
Because I have no experience with oil fired furnaces, I'm likely not the right person to respond, but if my experience with natural gas fired furnaces counts, I think I'd eliminate the upper and use only the lower port. By sizing the blower and providing an adequate amount of fuel, it should be more than adequate to melt anything you desire, maybe even cast iron (which I would not recommend).
As you alluded, the flame should not impinge on the crucible, but swirl around it, instead.
If you are not familiar with oil burners for furnaces and boilers, it might be a good idea to explore how they work. I seem to recall, in the distant past, someone using just such a burner for a melting furnace, with good results. Dealers that sell and install such heating systems are likely to have one that has been removed, possibly free for the hauling. With the high price of heating oil now, I can't help but think that many are switching to other heat sources.
If you pre-filter waste oil (not an easy task, but it can be done. I've done it successfully for years), you can use waste oil in a heating oil burner. It would have to be heated, or you would have to change the nozzle to one that might be better suited to the application. There's also a waste oil burner on the market, but I am not familiar with how it works.
Do keep posting on your progress.
