Heavy Duty Light Thingy
seal killer
Post by seal killer » Wed Jun 02, 2010 10:26 pm
All--
I would like to have a heavy duty light that I could mount on the far left or right side of my mill table in a t-slot. The arm would use two or three joints for flexibility and let me positon the light (incandescent, probably) where I need it most . . . close to the work.
While I am thinking about this, it occurs to me that the same mount implied above but with a ring light magnifing lens would be good for the other side of the table. Both the light and magnifier would be capable of being placed in the vertical position to get them out of the way.
Does such a thing exist or do I build it? Sounds easy. :)
Thanks.
--Bill
You are what you write.
mechanicalmagic
Re: Heavy Duty Light Thingy
Post by mechanicalmagic » Wed Jun 02, 2010 11:25 pm
Bill,
Many of the standard desk lamps have a clamp-on device. Just a hole, with a "J" bolt that grips underneath. I made the proper size hole in a block, and have it secured with a turret bolt on the mill. Not elegant, but it gets partway there. The problem; too few degrees of motion. Something seems to be in the way all the time.
A better solution would be to have a ball joint at each joint. Easy to make, if you have a lathe,
Dave J.
Post by Harold_V » Thu Jun 03, 2010 12:30 am
Bill,
BP mounts the work light on the left hand side of the mill column. That's the best possible choice in that if you mount your light to the table, it will constantly be moving away from the point at which you wish it to aim. Likely not much of a problem if you work with your table and saddle in a fixed position, but that's a little unusual for typical mill work.
The lights they mount have a double ball assembly at the end of two arms, plus a swivel at the lamp, proper. You can position the light almost anywhere you desire.
When you get yours up and running, be certain to buy rough service bulbs. They easily withstand movement and vibrations, unlike the typical lamp.
BadDog
Post by BadDog » Thu Jun 03, 2010 5:18 am
I use Luxo magnifying lights on both my fab/work table, and on the lathe. I like them very well, but don't have one for the mill.
EdK
Post by EdK » Thu Jun 03, 2010 5:56 am
I use goose neck lights on both my mill and my lathe. The goose neck allows you to position the light just about anywhere you want it. This is the one I recently got from Enco for my lathe:
http://www.use-enco.com/CGI/INSRIT?PMAKA=328-5479
It comes in different style mounts and can use compact fluorescent or incandescent bulbs and has a 24" goose neck.
I've also made my own goose neck lights by purchasing microphone goose necks from Musicians Friend and getting some track lights from the local home center and mounting them to the goose necks.
Ed
seal killer
Post by seal killer » Thu Jun 03, 2010 7:19 am
All--
Thank you all for the suggestions. If I come up with something "different" (highly doubtful) I'll post it.
--Bill
Frank Ford
Post by Frank Ford » Thu Jun 03, 2010 9:25 am
Cheers,
Frank Ford
SteveHGraham
Post by SteveHGraham » Thu Jun 03, 2010 12:07 pm
Do you really have to use highly technical language like "heavy duty light thingy"? A lot of us are just amateurs, and this arcane jargon confuses us. Can't you just call it a "doodad"?
Frank, do you have any idea how many lumens that light is? I can get 150-lumen flashlights at Costco for 6 bucks, so I have to wonder if technology has moved forward to the point where a tiny flashlight, a magnetic base, and some kind of gooseneck will do as much as an expensive AC light.
seal killer
Post by seal killer » Thu Jun 03, 2010 2:49 pm
SteveHGraham--
"Arm thingy" is a highly sophisticated and technical term. Don't worry about it. Just call it something like a "high power incandescent lamp with fixture and three degree of freedom mount."
Frank Ford and I are a pair of fellow sophisticates. Here is his use of the phrase and description of the construction of the device: Arm Thingy Light Deal.
--seal killer
SteveHGraham
Post by SteveHGraham » Thu Jun 03, 2010 3:32 pm
Sometimes it seems kind of pointless to try to come up with anything new, because whatever it is, Frank has already done it.
Jose Rivera
Post by Jose Rivera » Thu Jun 03, 2010 4:14 pm
Frank is the type of person that dazzles with brilliance !!! 8) 8) 8)
steamin10
Post by steamin10 » Thu Jun 03, 2010 5:53 pm
:lol: :lol: :lol:
:roll:
You mean Frank is his own guiding light ???
