When it comes to welding up , say a cube, in square tubing, you will have all kinds of fun keeping square. This is where those magnetic arrow point looking things really can help. Besides a dozen C-clamps and a few pipe based bar clamps for woodworking, the magnets are fast and simple.
First importance is prep, sqare ends that fit with minimal gap, without rust, paint , or oil. And every thing set up square to start with. Measure twice, weld once. When ever you weld a side on the tubing, its gonna pull. You can help yourself by tying the tubes together, with dot spot welds, while the pieces are clamped to anything substantial, even a sheet of plywood to resist free movement. If you catch it while just tacked, you can use a parting disc in a 4" grinder, and get things right again, and retack.
When you start doing final passes, you may notice a small diference where the corners of the tubes come together, as the heat seems to bleed off a little there. Welding around the corners, is for me the hardest part to get right, and I got a two handed death grip on the Mig Gun, to keep my speed and distance, while changing angles. While welding flat is the norm, and easiest to start with, a Mig is quickly adaptable to all position. So, as you move along, practice by making a hangmans platform. A couple of odds and ends, and make a gallows that has a piece of chain or hook from the simple stick, like and upside down 'L'. Full weld everything there. Do all the positions, you will be better for it.
_________________ Big Dave
Be Alert! The world needs more Lerts.
