Rebuilding a 5C Spin Indexer
JimGlass
Post by JimGlass » Tue Nov 09, 2010 8:54 pm
The imported spin indexers really have a fine cast iron base and spindle. Over the years I have made improvements to my spin indexer to make it work better.
First, they must have 1/16 clearance between the spindle and drawbar. The threads on the collet have the job of centering the drawbar. I made a sleeve bearing that is pressed into the spindle the keeps the drawbar centered. The sleeve is Nothing fance and probably has .005 or .010 clearance on the drawbar. Much better than it was. The sleeve bearing could be made of a number of materials. Aluminum, steel, plastic.
Next, get rid of all the setscrews. The black ring between the drawbar and the cast iron base needs to go altogether. The black ring has one or two setcrews that is intended to take out the endplay of the spindle. They work okay until the 5C collet is loosened. But when the drawbar is tapped to loosen the collet the retaining ring moves so now there is endplay in the spindle again.
The crank on the drawbar is held in place with setscrews. I took some experimentation but I found a point where the drawbar tightens the collet. The drawbar crank is pulling against the spindle and the collet. Take the setscrews holes and drill and tap the setscrew hole through the drawbar so the drawbar crank can never move again unless the setscrews are removed. The setscrews double up as pins.
The indexing plate is held in place with a threaded ring. Remember it is possible for the indexing plate to move. Always use the little pin with the knurled head to lock the spindle through the bushing on top of the indexer so the collet can be tightened or loosened. Lock the spindle with the cast iron base.
Finally, we still need to address the spindle endplay. I made a brass sleeve for the outside of the spin indexer spindle. I drilled through the sleeve and the spindle in two places and pinned the two together with rollpins.
Next I threaded the sleeve. I do not recall the OD but the pitch was 32 TPI. I machined the threads on my lathe and checked them for depth with thread wires. Then I took two steel rings and knurled the outside and threaded the inside to mate with the threads on the brass sleeve. One threaded ring adjusts the endplay on the spindle and the second ring locks the first ring in place
The spin indexer is now dependable and a pleasure to use.
Hope this was of interest,
Jim
www.outbackmachineshop.com
Russ Hanscom
Re: Rebuilding a 5C Spin Indexer
Post by Russ Hanscom » Tue Nov 09, 2010 9:10 pm
Thanks for all the great upgrade tips
ken572
Post by ken572 » Tue Nov 09, 2010 10:07 pm
Jim,
Thanks for the great rebuild tutor and visual aid's.. 8)
This was also a GREAT READ.
Ken.
One must remember.
Ken.
JackF
Post by JackF » Tue Nov 09, 2010 11:24 pm
Jim,
Thanks for this thread. I have used my indexer once or twice with success but after this I can see I have some work to do. :D
Jack.
randyc
Post by randyc » Tue Nov 09, 2010 11:43 pm
Nice re-engineering job - the Chinese government should put you on retainer, LOL ! All of your other posts and suggestions are also much appreciated.
Cheers,
Randy C
chazc
Post by chazc » Wed Nov 10, 2010 1:59 am
Hi; Jim nice job ,It is strange to me how a lot of people on the other side of the country and years apart come up with almost the same thing .although you did a lot nicer job than I . I tack welded the index plate to the spindle and made a four spoke sleeve to tighten the collet. I also reversed the index plate on an old one so I could use it upright. Man I love this board index. I wish I could post pictures but I still don't get it.
chazc
Post by Harold_V » Wed Nov 10, 2010 2:40 am
chazc wrote:I wish I could post pictures but I still don't get it.
It's dead easy, chazc.
Give this a go:
As if you intend to reply to this post, click on the reply button. That will take you to the page that allows you to compose your reply, which is the same page you'd use for a post. Below the box in which you enter the text for the post, below the rather deep blue line, do you see a little box (a button) , to the left of center, that says Browse? If you do, click that button. That allows you to go to the place in your computer where your pics are stored. Go there and select the picture you'd like to post. Follow instructions on the screen and it's a done deal. It takes only seconds.
Need more help?
Just ask. Most of these guys will be happy to lend a hand.
JimGlass
Post by JimGlass » Wed Nov 10, 2010 7:00 am
Chazc:
A second option.
Often I post pics that are stored at Photobucket.com. Photobucket is free and a wonderful service. You open an account and start uploading your pictures. Eventurally you start having separate photo albums where pictures can be store by topic.
If you want to post a pic in your post I go to photobuck (saved in my favorites). Place your mouse cursor on the pic you wish to post then move down to where it says IMG CODE. When IMG CODE is highlighted in blue go to EDIT and COPY.
When you are typing your post and you want to include the picture just go to
EDIT then PASTE and the IMG CODE will appear. You will not actually see the picture until you either preview or submit your post. You can post more than one picture this way. Once the pics are stored at photobucket it is easy and fast to include pics in your posts. Part of the reason I almost always include a pic in my posts.
Below is the picture I selected at Photobucket.com
If I'm using my digital camera software and I'm saving a digital picture for photobuck I always save with "best for web" size. This is usually a nice size yet not to large and all my pictures are the same size.
If you don't understand this just ask.
Jim
Picture stored at Photobucket.com
ken572
Post by ken572 » Wed Nov 10, 2010 7:10 am
Hi chazc,
I just thought of something.. :idea:
How big are your pictures??
What type are they?? .jpg or .bmp .gif or ???
Ken.:)
One must remember.
Ken.
fourjc
Post by fourjc » Wed Nov 10, 2010 9:31 am
I like your mod to remove the end play on the spindle, I would also like to shorten the spindle some day but when its cut its gone and I lose the flexability to move the spindle out. Shortening the spindle would allow me to use the indexer in the vertical position without loosong too much height.
I also made this mod to my spinner for grinding pins on my surface grinder, works great, I dont grind many pins or shafts so I am not too worried about the kack of bearings in the spindle.
coal miner
Post by coal miner » Wed Nov 10, 2010 10:34 am
JimGlass , a good post . Used some of your mods on mine the first time it came out . The short comings that you addressed made the indexer more user friendly . I use mine a lot , actually more than I thought . The indexer on the mill and the hex and square block 5-C adapter for the lathe are some pretty handy tools for low budget use . You can do a lot of things with them , as someone said use your imagination . Since I got a real rotab I still have the spin indexer to do the quick and easy jobs and it sure is simple to set up .
The more I learn , The more I don't know !
JimGlass
Post by JimGlass » Wed Nov 10, 2010 11:09 am
Fourjc: I'll be that works very well. The indexer fit between the cast iron base and the spindle is pretty amazing. Keep it oiled up and it will last for a long time.
My cylindrical grinding attachment that I made. It can also be used for indexing. It is a Harig knockoff.
For grinding angle and tapers;
If anyone tries building one of these it is best to use ballbearings for this purpose $$. I used inexpensive bearings. I can detect the cheap bearings in the grind finish. Not exactly like the real Harig but close.
Mini cylindrical grinder. Uses a DA-200 collet chuck for a spindle.
Jim
