The Home Machinist!
It is currently Sat May 25, 2013 3:30 pm
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2, 3  Next
Author Message
 Post subject: Narrow gauge Kozo shay
PostPosted: Thu Dec 30, 2010 5:57 pm
Offline
I am working on scaling down Kozo's original shay plans to 1:20.3 (F Scale).
Has anyone built a narrow gauge shay based on Kozo's design?
I'm new to the forum and I know how to use my Sherline lathe and mill, but I'm not an expert machinist.
I'm looking forward to learning some new techniques from you folks.
Thanks!
Top
 Profile
PostPosted: Thu Dec 30, 2010 10:14 pm
Online
I can't help with your inquiry, Dan, but I'd like to welcome you to the forum.
_________________
Top
 Profile
PostPosted: Thu Dec 30, 2010 11:33 pm
Offline
Hi Dan and welcome!! Dwight Ennis posts on here quite frequently. He has built several small locos I think all narrow gauge. His current post is under my RRSC 4-4-0
_________________
www.jdlocomotiveworks.com
Top
 Profile
PostPosted: Fri Dec 31, 2010 12:07 am
Offline
I would like to add something -- What is the difference between the new shay and the old shay? Looking at getting the Shay book from Kozo, and not sure what to get.
Thanks!
Mike
_________________
CEO of Walsh Locomotive Works
http://walshlocomotiveworks.blogspot.com/
Top
 Profile
PostPosted: Fri Dec 31, 2010 9:12 am
Offline
Mike:
Kozo's first Shay book is based on the early Shay engines of the 1880s. His second Shay book, The New Shay, is based on a Shay of the 1920s. Both books thoroughly describe the construction of their respective locomotives. The latter book, however, contains additional information about copper boilers, small bolts, O-rings, safety valves.
Hope that helps...
Neil
_________________
Editor - Live Steam & Outdoor Railroading
Allen Mogul under construction
Electric RS3
Stationary Steam
Top
 Profile
PostPosted: Fri Dec 31, 2010 2:56 pm
Offline
Kozo designs are all based on standard gauge prototypes. If I remember correctly, Ed Hume has built many of Kozo's engines in F scale. At least the Heisler and the Climax he's done. I think the Heisler is shown on the page below but I've also seen the Climax somewhere. You can checkout his site at: http://www.thms.tedatum.com/BBoard/Hume01.html
Ken-
Top
 Profile
PostPosted: Fri Dec 31, 2010 5:25 pm
Offline
Ed Hume did a gorgeous Kozo Climax in 1:20.3 scale, to include skew bevel gears, exactly to Kozo's plan.. Kozo did the Climax in metric so Ed used a scale of 1mm = 1/32" and slightly adjusted the gauge on the wheels. Everything comes out in inch perfectly and is almost spot on F scale.
Here's Ed's flickr slide show:
http://www.flickr.com/photos/edhume3/sets/72157600964223180/
_________________
Bob Sorenson, Las Vegas, Nevada
Top
 Profile
PostPosted: Sat Jan 01, 2011 12:46 am
Offline
Since the Kozo Shay is standard gauge, if you rescale it to F (1' = 15mm), it would make a nice locomotive. The problem I see is when you put the 3' (45mm gauge) narrow gauge trucks under it. This will be too much mis-alignment between the engine shaft (standard gauge locomotive location)and the truck gear shafts. I figure about 10mm. In the plans there is about 1mm offset for the standard gauge loco. The Heisler and Climax do not have this problem. I would suggest some research of prototype NG shays and see how they handled this issue.
Top
 Profile
PostPosted: Sat Jan 01, 2011 1:01 am
Offline
I've only see the opposite situation, where they slope outwards to accomodate standard gauge on a smaller locomotive.
For narrow gauge, if you have a boiler that's too big you have to offset it more (messing up the balance) to get the cylinders inwards enough. So it's probably a careful compromise between boiler diameter, offset and cylinder placement.
Here are a few pictures I found with some examples of cylinders sloping outwards to the shaft line for NG to standard gauge. I suppose you could do this in reverse, sloping inwards.
The Heisler is the easiest geared engine to convert gauges back and forth, I believe there is someone out there with an engine that has two sets of trucks, one for 4 3/4" and one for 7 1/2" gauge.
And do check out Ed Hume's pics. He did a stunning job on the Heisler and Climax in Gauge 1 using the above described conversion technique.
I am not sure but he might be doing the Shay as well, haven't talk to him in a while. Ed and I went to Japan and visited Kozo several years ago.
_________________
Allen Models Chloe, MEG Steam "Wendy", 3/4" scale "Anny"
Darjeeling B-Class project - sonadaworks.com
Photography and more - www.mikemassee.com
Top
 Profile
PostPosted: Sat Jan 01, 2011 1:19 am
Offline
Harlock,
Would you care to elaborate on your opinion on this?
Thanks,
Doug
_________________
"Aim to improve!"
Top
 Profile
PostPosted: Sat Jan 01, 2011 2:30 am
Offline
On shay's Lima would tilt the engines any which way needed to get the shafts to line up. It's common on 50+ ton narrow gauge Shays for the engine set to tilt inward.
Here's a good site for reference: http://www.ShayLocomotives.com
Cheers,
Curtis F.
_________________
16 Years of SolidWorks experience...now I feel old.
Top
 Profile
PostPosted: Sat Jan 01, 2011 3:37 am
Offline
Doug_Edwards wrote:
Harlock,
Thanks,
Doug
The main drive shaft runs down the center of the engine, the two cylinders acting like a V-twin. Although I guess the Climax is also center-shafted.
So the shaft doesn't have to line up with one side of the trucks, unlike the Shay. Always in the same place regardless of gauge.
--Mike
_________________
Top
 Profile
Who is online
Users browsing this forum: Google [Bot], Lovesthedrive and 5 guests
Search for:
Jump to:
