A progress report
Last weekend being Memorial Day Weekend, I spent all day Saturday @ LALS Spring Meet smoozing and watching other people's trains. Sunday morning, no winds, I got an HF vertical whip up on the house. Monday, I drug out the chop saw to cut the material for the ash pan figuring I got the frame upside down, might as well "get er done" since it WILL have a boiler some day. But, as my HF (pos) chop saw started blowing the circuit breaker, there was a change of plans.
During the last week, I took in the 6" wide bar stock to my local weld shop who also does hitches (Dales Hitchin' Station in Lancaster, CA
http://www.daleshitchinstation.com/ ). They've done excellent work for me before (put a hitch on my last truck) and cut out the triangular part of the front and back part of the ash pan. The rest of the bar stock and angle iron, I dropped off with Patton's Steel where I've been buying my materials (
http://www.pattonscorp.com/catalog/ ), gave them the lengths and quantity, and the work was done at a really reasonable cost. I know, it's a shameless plug for a couple of companies I give my business.
The other day, I clamped everything together for fit and got side tracked on other business.
File comment: Primary parts of the ashpan clamped together inplace.
File comment: Close up of ashpan parts clamped together.
Today, I turned and burned, making chips and assembled the ashpan.
At this point, with my hands sore from the wrenches (and its been painful to type on the keyboard tonight
), I quit for the night ready to drill the mounting holes tomorrow.
File comment: A closer look at the Ashpan in the drill press.
Next I'll attach the ashpan doors, hinges and put in the bottom.
A future conundrum is: Will it be fired off coal or propane? For some, I know coal is the only thing to burn. So, before I attach the ashpan in the frame semi-permanent, I was thinking of drilling three or four 1" dia. holes in the side of the bar stock over the ashpan doors and like a barbeque, add a sliding cover to vary the air intake (understanding propane burners will need more air to work efficiently). What do you all think?
