Today was office day for me.
Washed both vans, made some phone calls, and did an experiment.
It took a bit to find some "washing soda" as it not sold at either of our local grocery stores. I did stop by the local paint and body place and pick up a pint of "Rust-Mort" for 20 something dollars, it is 75% Phosphoric Acid, before I found Arm and Hammer "Super Washing Soda" at the local Ace Hardware for 4 something.
As anyone who has read my posts knows, I have lot of rust to get rid of. =:0
Here is the before picture of a swivel base for a 6" vise.
In the 5 gallon bucket. Added soda and water. Took a piece of flat bar, and used a c clamp to hold it to the side of the bucket. Connected battery charger. Left is set for a couple of hours. Pulled it out to have a look and things were going well. Blasted it with a hose, couple of quick hits with a SS wire brush and back it it went. Let run for about 5 more hours. Dried it off, add some oil, took some paper towels and a T-nut cleaner to the inside of the track. And this is what I have now.
I did not flip it around during the process, so that the anode was on the back side. I think it was in good shape to begin with.
I will take picture of the set up while doing the next parts.
I have not tried the Phosphoric Acid yet. This is working so well it is like magic.
I will take a wire brush to the degree ring where the numbers are, to make it easier to read. Then I need to find it a home, out of the way, in the shop.
Thanks for having this discussion, it is going to save me a lot of time, money, less paper towels/rags, less time around solvents, no air born rust from brushing. It's just a win win in my book. Should have done it sooner.
Now to rig up a multi-part setup, and do a small vise. Who knows what else may hit the soda bath soon.
