The Home Machinist!
It is currently Fri May 24, 2013 12:35 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
PostPosted: Thu Jun 30, 2011 7:38 am
Offline
For my boxcab engine built from 1/2" plywood, I want to mount headlights on either end. I don't want to use the type that stick out and look all fancy (like on a steam locomotive) but instead wanted something that essentially would flush mount with a nice polished bezel around it.
LEDs are easy on the current but they look like, well, LEDs. I thought about gutting some flashlights for the parts but a search online wasn't all that helpful. I want my headlights to be about 1.5" diameter and powered by batteries independent of the deep-cycle engine batteries.
Any thoughts?
_________________
Top
 Profile
PostPosted: Thu Jun 30, 2011 7:55 am
Offline
Beej,
Check out Nelson Reidel's method for a headlight. YOu can use the same type of headlight but that doesn't have LED's.
http://www.nelsonslocomotive.com/Shay/E ... icalII.htm
You can make the housing look like anything you want including recessing the thing with a groove so you screw on the bezel/lens from the outside and the rest is inside the cab.
I have spent more time than I want to admit just poring over his webpages.
Brian
Top
 Profile
PostPosted: Thu Jun 30, 2011 7:05 pm
Offline
Here is what I used. These can probably be mounted flush instead of on top of the hood:
http://www.electricscooterparts.com/headlights.html
_________________
Dan Watson
Building IC mikado in 1.5" scale
Top
 Profile
PostPosted: Sat Sep 03, 2011 1:08 pm
Offline
I've done several headlights using the reflectors and lenses from cheap dollar store flashlights. Searching around, you can find a flashlight that is the right size to use. I use incandescant bulbs in lieu of LEDS because they are more authentic in brightness, especially on older models.
_________________
Mr Ron, Almost as smart as the average bear.
Top
 Profile
Who is online
Search for:
Jump to:
