holding small parts
refinery mike
holding small parts
Post by refinery mike » Sat Jul 16, 2011 8:38 am
I built this jig for holding small parts, while i cut sand or grind them. it is made out of O-1 steel and is kind of a cross between a jeweler's hand vice and a machinist's parallel clamp. I am sure there are all kinds of small part holders out there but this is one that i like.
"Do you know what that part was? .... Yah Hot! "Curly"
Al_Messer
Re: holding small parts
Post by Al_Messer » Sat Jul 16, 2011 11:19 am
Good on yer, Mate!!
Al
Al Messer
"One nation, under God"
oldbrock
Post by oldbrock » Tue Jul 26, 2011 1:48 pm
Yes, I like it. As if I didn't have enough projects. Peter
Difficult done right away, impossible takes time.
stevec
Post by stevec » Tue Jul 26, 2011 4:17 pm
It's on my "never ending" list . Looks like a time and finger saver!
Thanks!
JimGlass
Post by JimGlass » Tue Jul 26, 2011 7:34 pm
Good idea. I should make one.
Jim
www.outbackmachineshop.com
Conrad_R_Hoffman
Post by Conrad_R_Hoffman » Tue Jul 26, 2011 8:12 pm
Nice holder! The nut is notched so it's left handed and you probably stole it off your oxy-acetylene torch for some no doubt questionable purpose.
Conrad
SteveM
Post by SteveM » Wed Jul 27, 2011 11:10 am
Nice tool.
While Mike didn't mention it, notice that both the top and bottom have a slot so that you can slice deeply into a part, or even cut it in half, while it is held by the clamp.
refinery mike
Post by refinery mike » Wed Jul 27, 2011 4:10 pm
Just a note, the holder is made out of O-1 tool steel but i wouldn't harden it. Just in case the saw blade were to nick the holder. And 0-1 is plenty strong even in the annealed state.
KenHMT
Post by KenHMT » Tue Sep 25, 2012 2:10 pm
refinery mike wrote:I built this jig for holding small parts, while i cut sand or grind them. it is made out of O-1 steel and is kind of a cross between a jeweler's hand vice and a machinist's parallel clamp. I am sure there are all kinds of small part holders out there but this is one that i like.
Great little clamp!
I've added it to the growing homemadetools.net database: http://www.homemadetools.net/clamp-for-small-parts
Ken
refinery mike
Post by refinery mike » Wed Sep 26, 2012 9:32 pm
i am honored to be included. And you can be sure i will be checking out your web site soon. thanks for the address. i just had a few minutes to view it and it looks like quite a collection. Health problems are consuming almost all my time right now. But when my wife gets well, you can bet i will be snagging some good ideas from you. best wishes
JackF
Post by JackF » Thu Sep 27, 2012 8:33 pm
Nice tool.
I'm guessing you are cutting the nut in half to make a half nut, just a guess. :roll: :wink:
Jack.
refinery mike
Post by refinery mike » Thu Sep 27, 2012 8:44 pm
who told you i was half nuts. that is supposed to be a secret!
