The Home Machinist!
It is currently Sun May 19, 2013 6:00 am
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4  Next
Author Message
PostPosted: Fri Sep 30, 2011 9:21 am
Offline
Made some headway last night. Wired all of the motors and G540, mounted the motors on the machine and I was up and running. Made some test cuts with desk engrave staying under the 500 line limit. Only problem I had was my z axis was opposite. Quick search on google and I was able to find the switch on Mach 3. I am totally impressed with how this mahine cuts and the accuracy. Using one of the wizards in Mach I millboared a 1" hole with a 5/8 hss 2 flut endmill and it acutally came out pretty well. Measured with a vernier along the x was 1.001" and on the y was 1.000. Now I am sure the CMM would tell a bit better but for what I want to do with the machine this should be fine.
Now for the wiring clean-up and cutting a hole for the G540 in the original TMC-1000 case.
Question: When mounting the power supply in a case would you mount it on a rubber pad? May be some small jig legs?
Kevin.
_________________
BUILDING IT IS MORE FUN THAN BUYING IT
Top
 Profile
PostPosted: Fri Sep 30, 2011 10:26 am
Offline
Site Admin
Kevin.
Outstanding. Gottal love the G540. Don't worry about the rubber pads for the power supply....
pictures!
Marty
_________________
Top
 Profile
PostPosted: Thu Oct 06, 2011 9:15 am
Offline
Did my first "real" project with the cnc mill. I did some 3d cutting for a name plaque for my Mom's cat. I burried it a few days ago. The design was done in Solidworks and the 3d milling was done with a product called freemill from Rhino. Program was with a 3/16 ball cutter and a 0.02 stepover and took about 40min. to complete. The software is very basic but did a great job considering its free. I will post a few pics when i can.
_________________
Top
 Profile
PostPosted: Wed Mar 21, 2012 10:05 pm
Offline
Hello! I have obtained this very same mill, and just loaded it onto the bench. same ol motors installed. but the spindle motor is a bit different. This is baby's first CNC project :D. Could you give more info one how much and what exactly you used on getting her running? The spindle circuit on the back looks the same but im missing that relay i think. Wish me luck!
Top
 Profile
PostPosted: Thu Mar 22, 2012 7:12 pm
Offline
Nice little machine. Especially if it uses R8 tooling. With R8 tooling, you could adapt Tormach TTS holders and have sort of a quick change tool holder set up.
_________________
You can buy good parts, or you can buy cheap parts, but you can't buy good cheap parts.
Top
 Profile
PostPosted: Mon Apr 23, 2012 9:40 pm
Offline
Hi guys,
I looked at a couple of mills the other day, D&M 4 and TMC 1000.
Is it fair to say that bringing either up to date with a retrofit is approximatly $600.00 ish?
What would you say fair market value is for either? I want to give a fair offer.
Which is the best overall?
I was looking at a self built CNC router, but would prefer to do a retro fit for the first one.
Chips
Top
 Profile
PostPosted: Mon Apr 23, 2012 11:13 pm
Offline
Site Admin
Chips wrote:
Hi guys,
Chips
I would say that's likely a fair estimate for the parts. Buy the Gecko G540 and don't look back. As for.the value of the machine. Well I suppose it depends on condition. If they are non functional $300ish?
I would say though that the D&M4 you will likely be able to leave the stepper motors and drivers and just use a breakout board like the C10 from CNC4PC.COM and save quite a bit of money and time. If the machine is complete, then it may be my first choice for an easier retrofit. I did a Lab-Volt 5300 lathe and I believe they were built by D&M. I was able to reuse the stepper drivers and stepper motors. Just ditch the PC104 control and replace with a breakout board. You can also control the DC spindle motor from Mach3 with a C6 spindle speed control from CNC4PC. Fun stuff....
Good luck
Marty
Marty
_________________
Top
 Profile
PostPosted: Mon Apr 23, 2012 11:34 pm
Offline
Marty, thanks for the tips and ultra fast reply, it sure helps.
Chips
Top
 Profile
PostPosted: Mon Apr 23, 2012 11:45 pm
Offline
Site Admin
Chips
Let us know how it all shakes out for you. Here are a couple pictures of the Lab-Volt I converted:
https://picasaweb.google.com/marty.esca ... abvolt5300
_________________
Top
 Profile
PostPosted: Wed May 09, 2012 6:52 pm
Offline
Chips,
Your about right for the cost to upgrade. I purchased almost everything from a company on the net Keling. They were good to deal with, no problems. I went with new steppers and a g540 and Mach 3. The TMC_1000 is a great little machine to get you started. I have done a great deal of parts on it and I have expert machinists complementing me on the finish. I paid 400 cdn for my machine from a local high school that was clearing out machine shop equipment. I wish I had more money at the time I would have bought everything they had.
Hope i'm not too late to the party, life is really busy.
Kevin
_________________
Top
 Profile
PostPosted: Wed May 09, 2012 8:48 pm
Offline
Hi Guys,
I am doing the project to help out the local school. They want to put one of the machines back in service if possible rather than sell at the moment.
I am picking up the D&M 4 machine on Friday, so should be able to get a look inside and see what we have in the next couple of weeks.
When I have got the covers off, I will post more.
Chips
Top
 Profile
PostPosted: Mon May 21, 2012 1:49 pm
Offline
Hi guys,
I have been able to get the D&M 4 machine running using all the original parts and computer.
The first problem is the battery on the old 386 computer is dead, but I managed to get around it for the moment.
The first order is to verify what is usable and what is not before putting hand in pocket.
After I had given it a clean and a bit of oil, I ran a simple program (original DOS program is ok but not standard G code).
Second problem: It looks to me like there is a problem with the steppers as it is loosing its place during movements.
I am imagining that it is missing steps and loosing its position.
I am going to remove the steppers one by one, and ensure there are no tight spots in the travel.
Also I am missing the Estop button.
Chips
Top
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
