The Home Machinist!
It is currently Wed May 22, 2013 6:25 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: 90 degree straight edge
PostPosted: Fri Oct 14, 2011 8:16 pm
Offline
If you have used a torch much at all, you probably know how to make and use a straight edge. I make a 4 1/2" straight edge with a fence so i can cut angle and channel off square and clean. I personally have never before, seen anyone else use a fence on a straight edge. but they are so handy i would hate to have to do without one now. The picture shows one that i have used for over 35 years now. It is hard to believe but all the metal is stainless steel. It is best to make the guide bar, at least, out of stainless steel as it is easier to clean up. The wooden handle on top is a must,(things get hot) Your left hand rests on that wood knob and your, gloved, left thumb guides the side of the torch as the torch tip slides along the edge. The fence is bolted on so it can be replaced if dropped. well hope some welder can use this to advantage.
File comment: looking from the bottom side.
Top
 Profile
PostPosted: Fri Oct 14, 2011 9:44 pm
Offline
Thanks for a neat idea - I will ad one to my projects list
Top
 Profile
PostPosted: Sun Oct 23, 2011 8:59 pm
Offline
I have been thinking about trying to make something along these lines to use with my plasma cutter. Thanks for a great idea.
Top
 Profile
PostPosted: Mon Oct 24, 2011 1:27 pm
Offline
I generally use a 2.5 inch angle iron, for cutting straight. But beware, heat buildup is uneven, and can bend the straight edge without notice and warning, with the obvious drift encountered..
This is why commercial cutting tables use bridges to isolate the 'straight parts' of reference from heat, and movement.
That being said, any tool or gizmo that produces a better cut is welcome in my shop.
_________________
Big Dave
Top
 Profile
Who is online
Users browsing this forum: No registered users and 3 guests
Search for:
Jump to:
