Allen axle pump
crackerjackhoghead
Allen axle pump
Post by crackerjackhoghead »
I'm wondering if the Allen axle pump performs satisfactorily or If I should pursue something else. I will also have a pair of injectors.
Jeff
cbrew
Re: Allen axle pump
Post by cbrew »
crackerjackhoghead wrote:I'm wondering if the Allen axle pump performs satisfactorily or If I should pursue something else. I will also have a pair of injectors.
Jeff
I never installed it on the American and will not on the ten wheeler. Two injectors (SuperScale) do the job just fine
Just my 2.5 cents
Trainman4602
Re: Allen axle pump
Post by Trainman4602 »
Axle pumps are a throw back to 1 inch and 3/4 scale they are not need in 1 1/2 scale. Two injectors are all that's need. The larger modern locomotives did not have them.
Axle pumps are noting but a pain
FLtenwheeler
Re: Allen axle pump
Post by FLtenwheeler »
Hi
I have an axle pump on my 10-Wheeler. I used a rubber cup that I purchased from Cole’s Power Models and a nylon O-ring in a grove behind that. I had the ball lift set to high at first but once I fixed that it has never giving me any problem. I do have 2 injectors that work great as well.
The pump puts most of the water I need in the boiler. Then I use the injectors to top it off once every other time around or so.
Tim
Andy R
Re: Allen axle pump
Post by Andy R »
I agree with Chris and Dave.
My 7.5-inch mogul is a mongrel that incorporated many Harpur (pre-gene Allen) components. The axle pump siezed up on me during a meet. It was NOT fun trying to disconnect the eccentric under a hot locomotive in order to clear the main. I made a new pump to the same design. It ran well, and with the bypass cracked open, provided ample water. But it too siezed up, again during a meet. At least i had the tools available to disconnect the eccentric. I have since removed the pump and all the associated piping and use the Ohlencamp injector. Another injector is on order from Superscale.
The problem with big pumps is that they do not scale-up from the 3/4-inch scale locos. The rams need to be guided just like the steam pistons are guided ... but i've never seen a guided ram design for an axle pump.
John_S
Re: Allen axle pump
Post by John_S »
I think it comes down to builder's choice for axle pumps.
My mogul has the eccentric on the axle, but I have no plans whatsoever of actually putting a pump on the loco. I'm going to put two injectors on and not bother with the extra work involved in the pump.
crackerjackhoghead
Re: Allen axle pump
I was hoping you guys would say that as I'd rather not put it on the engine. I thought I was going to be told not to rely on the injectors alone.
Jeff
cbrew
Re: Allen axle pump
Post by cbrew »
crackerjackhoghead wrote:I was hoping you guys would say that as I'd rather not put it on the engine. I thought I was going to be told not to rely on the injectors alone.
Jeff
Just go with Superscale and have screens on the water supply lines to keep the chucks out and you will not issues.
David Powell
Re: Allen axle pump
Post by David Powell »
While not quite relevqnt to the original question I would add that I have seen a number of axlepump arrangements on 3 1/2" gauge models which have given trouble or had short working lives, thanks to excessive angularity of too short eccentric rods. In a couple of cases I have solved such problems by rearranging the drive, using a longer dog leg shape eccentric rod, driven from a further away axle. to go above and around the axle nearest the pump. I will admit it looks a little strange, but it works smoothly, and the pumps seem to run for ages without attention to the gland packing. Hope this hint helps someone David Powell.
Re: Allen axle pump
Post by Bill Shields »
Then I guess I am a 'throw-back'.
I have axle pumps, steam driven pumps and injectors, as well as a hand pump.
I like having a pump that I can set and forget while running.
Properly designed, there is no reason why an axle pump should give any trouble.
10 Wheeler Rob
Re: Allen axle pump
Post by 10 Wheeler Rob »
The axle pump on the prints is will provide most of the water needed but is marginal in its sizing. This I confirmed with both caculation and the operqting experance of mogal operating at our club.
If you want the ability to run solely on axle pump(s) capacity I would recomend either increasing it to 5/8" bore form 1/2" or going with dual 1/2" pumps.
As mentioned previously one ejector will give you the capacity needed, a second the back up needed or safe operation. Ejectors have the advantage of being mounted where they can be easily maintained.
Rob
Greg_Lewis
Re: Allen axle pump
Post by Greg_Lewis »
Well-known Nevada steamer Cal Tinkham has a 5/8 dia. ram pump on his engine and it's a set-it-and-forget-it arrangement. The injectors put out a lot of volume and require lots of on and off fiddling, but once the bypass is set on the pump all you need to do is pull the throttle and enjoy the view. The only time the injectors are used is when the engine has been sitting waiting for clear track ahead.
In the end everyone has preferences and it probably doesn't matter that much.
Greg Lewis, Prop.
