I know the Chicago model can.crackerjackhoghead wrote:Can the Superscale injectors be trimmed like a full size injector or are they all or nothing?
I never tried it with the economy injectors
also known as throttlingSteven E. Kuhn wrote:Trimmed???
Injectors made for, and used in the hobby for the past 35 years.... Ohlenkamp, Supercale.... are extremely reliable.Benjamin Maggi wrote:I recently observed a gentleman operating an engine equiped with two injectors only, no hand pump and no water pump. The water level got low, pressure started to drop, and he then couldn't get more water in because there wasn't enough pressure to run the injectors.
Thus, the only option was the drop the fire and start over. Had he equipped the engine with an axle pump or a handpump, he might have been able to get out of the situation. True, injectors are great when they work but if they fail it is nice to have another way to get water in. The axle pump is a pretty simple method overall....
