I'm afraid you did far better than I would have.stevec wrote:1) If it isn't broke, repair it untill it is....If it isn't broken, repair it until it is.
2. Everyone that lays brick needs their trowel.... Everyone that lays brick needs his/her trowel.
3. Your book is laying on the table....... Your book is lying on the table.
4. Mix the epoxy components together quick or it will set up before you can use it.... Mix the epoxy components together quickly or it will set up before you can use it.
5. Alot of us have ran a lathe for many years...... A lot of us have run a lathe for many years.
Them wood be my gesses
Good exercise, Marv.
