Boring Bar in Toolholder
Moderators: Harold_V, GlennW
SteveHGraham
Re: Boring Bar in Toolholder
Post by SteveHGraham » Tue Dec 06, 2011 7:02 pm
That's clever.
J.Ramsey
Post by J.Ramsey » Wed Dec 07, 2011 10:13 am
wlw-19958 wrote: Anyway, I've read about using a boring head in the tailstock to hold a center and
thus creating a way to off-set the tailstock center for taper turning. It sounds
like a creative way to do precision off-setting without having to off-set the upper
half of the tailstock itself. I haven't used this method myself because I have a
taper attachment on my lathe.
Here ya go.
J.Ramsey
Post by J.Ramsey » Wed Dec 07, 2011 10:40 am
Here's a couple tips/tricks I've learned using this setup.
Turn and harden a pair of ball nosed centers,standard 60 degree centers don't work very well in a 60 degree center drilled hole that is offset.The ball end center will run fine in the the center drilled hole.
I add a drop of oil on the centers and check tailstock tension frequently while turning.
Other than the 1.000 x 11" Aluminum piece pictured in the above post (I was showing a buddy how to do it) I use the steady rest I made to support the boring head to remove the flexing that's caused by the combined length of the live center and boring head.
SteveHGraham
Post by SteveHGraham » Wed Dec 07, 2011 10:43 am
That's neat. I was wondering how the offset affected the pointed centers, and you answered the question.
stevec
Post by stevec » Wed Dec 07, 2011 1:58 pm
I agree Steve and also nice job on the steady rest J.Ramsey :wink:
