For Sale Automatic Cylinder Cocks
We have in stock automatic cylinder cocks with 1/8" pipe or 1/4-28 threads for $125.00 a set of 4. No need for plumbing or linkage. Just thread em in and ready to go.
www.banninglocomotiveworks.com
www.littleengines.com
Re: For Sale Automatic Cylinder Cocks
Do you still have the automatic Cylinder Cocks for sale? I am in the proccess of Rebuilding a LE American and will need a set in the next several months.
Regards,
Doug
Regards,
Doug
Here's a strange question, and excuse my ignorance:
How do these work without a linkage?
Tongue firmly in cheek....very well!SteveM wrote:Here's a strange question, and excuse my ignorance:
Seriously, they work on the principle of prototype cylinder relief valves. There is a check ball in a chamber that is larger than the ball. When water is present the turbulence in the water keeps the check ball off of its seat allowing the water to be released. Once all of the water and its turbulence is no longer present...the ball snaps up against the seat closing the valve. Full sized railroads used these in conjunction with manually operated cylinder drains. This gave the engineman the ability to open and close the drains when needed. But the relief valves acted as back up in case you had water "carry over" and you had a slug of water enter the cylinders. The relief valves hopefully prevented damage to the cylinders from water carry over.
Keith
