whisperfan
Post
by whisperfan » Mon Dec 26, 2011 1:41 pm
I thought it would be nice to share some of the tips and tricks I have discovered, or stolen over the years.
If you have an Tips, Hints, or Ideas you want to share, please feel free to post them.
First one - This is a 2-part tip. If all you can afford is a cheap set of drill bits, that's cool! As you find you need a new one, buy a better quality one! Also, While it is always helpful to have a tap/die chart handy, why not just use a sharpie and write on the drill index some of the ones you use most often?
whisperfan on Fri Dec 30, 2011 5:35 am, edited 2 times in total.
whisperfan
Post
by whisperfan » Mon Dec 26, 2011 1:46 pm
This is a multi tip too
1. A dry erase board is great to have in the shop to jot down measurements or ideas
Get one that is magnetic and you can use a magnet to hang a piece of paper, blueprint or drawing.
Speaking of magnets ...
Neodymium magnets are pretty useful little things.
I use three 3/4" by 1/8" to put the chuck keys right where I need them. One on the Mill, one on the Tail stock, and another on the drill press.
Just keep them far away from where chips accumulate ... or chips will accumulate!
whisperfan on Mon Dec 26, 2011 9:43 pm, edited 1 time in total.
whisperfan
Post
by whisperfan » Mon Dec 26, 2011 1:48 pm
Label stuff!
Take an afternoon and label stuff! You will be happy you did!
whisperfan
Post
by whisperfan » Mon Dec 26, 2011 1:52 pm
Those little copper straps that plumbers use make a great way to store a drill chuck, a live center or an 8" file.
Look at the lathe - I store a chip brush and a 4mm allen wrench (for my tool holders) right there on the front. Just drill and tap a little hole for a 'L' shaped hook.
Then mount a spot for a file to debur and edge.
whisperfan
Post
by whisperfan » Mon Dec 26, 2011 1:54 pm
Do some wood working.
I made a wooden rack to keep my tool holders organized! I'm not sorry I did.
Ike
Post
by Ike » Mon Dec 26, 2011 2:29 pm
I had the local HVAC shop bend up this metal backsplash for my lathe.
Not only does it keep oil and swarf off the wall behind my lathe,
but I use a sharpy on it to jot down measurements and a couple of magnets
to hold paper drawings and notes where they're handy to look at when I'm
using the lathe.
The sharpy wipes off with a shot of carb cleaner or a dab of acetone or laquer thinner and a rag,
when I'm done.
refinery mike
Post
by refinery mike » Mon Dec 26, 2011 2:58 pm
As much as i love those new Neodidium magnets, I hate them too! any time my tools get stuck to one of them they get magnetized and start picking up bits of steel everywhere. The answer to unwanted magnetism is an AC electromagnet. You can snag them off of untold appliances before you toss them out. Solenoids, starters, hair clippers, fish tank bubblers, relays, anything that has an 120 volt ac coil in it. (DC will magnetize) Attach the coil to an old cord and plug it in. then pass the magnetized tool next to or through the coil. No more magnetism.
Caution, do not let these coils on for too long they may well overheat.
SteveHGraham
Post
by SteveHGraham » Mon Dec 26, 2011 5:58 pm
I like the tool holder rack. Mine tend to sit in the pan under giant piles of chips.
SteveM
Post
by SteveM » Mon Dec 26, 2011 6:56 pm
Go down to your local auto parts store and get some of those self-stick sunglass holders that you stick to the dashboard.
Put them on or near each machine and put a pair of safety glasses in each one.
That way you can never use the excuse "the safety glasses are all the way across the room". Also handy when there's a guest in the shop.
Qwas
Post
by Qwas » Mon Dec 26, 2011 7:46 pm
Need some soft jaws for a quick polish or sanding job? How about heat shrink tubing from an electrical supply place. Works for pliers too. If you heat (and shrink) slowly, you can make them re-useable.
- 4 inch 3 Jaw chuck with soft jaws in place.
Ike
Post
by Ike » Thu Dec 29, 2011 6:43 pm
I recently pulled the QC gearbox off of my lathe to r&r the bushings and a couple shafts in it.
I soon got tired of feeding the carrage by the hand wheel on the apron and the inconsistant finish that resulted,
so I started looking for a better way.
Low and behold, the crank handle for my tailstock slipped right on to the headstock end of my leadscrew,
key and all!
Using the hand crank on the end of my leadscrew and it's gear reduction in the apron to drive the carrage
I was able to get a much more consistant feed rate and finish for the parts I had to turn to get the gearbox
repaired and get my power feed back.
JimGlass
Post
by JimGlass » Sat Dec 31, 2011 9:22 am
Storage rake that is moveable. I used bi-pass closet door hardware to make this.
Stored possition
Jim
www.outbackmachineshop.com
