Installation techniques for a benchtop lathe
Moderators: Harold_V, GlennW
Wheels17
Post by Wheels17 » Sat Jan 21, 2012 1:42 pm
I'm a bit confused by some of the advice that I see on various forums about setting up a (benchtop) lathe. People seem to spend an inordinate amount of time and effort with expensive, high precision levels and shims. It seems to me that what they're trying to do is get the critical parts of the lathe in one plane, rather than truly level. Then they bolt the lathe to a heavy wooden top, that's going to move all over the place with temperature and humidity.
Most wood has low thermal expansion(2.7-3.0x10-6 in/in oF) but dimensional changes with moisture are very large. From 20% RH (winter) to 60% RH (summer), the moisture content ranges from 4.5% to 11%, with an expansion of 6%, with varying changes in the length, width, and thickness. Wouldn't this destroy all the careful work installing the lathe? Finishes on the wood would slow down the movement, but the movement would still occur. Steel has a bit more thermal expansion(7.3x10-6 in/in oF) than cast iron (6.0x10-6 in/in oF), but has no humidity effects and my shop is pretty well controlled for temperature.
I've seen 1 1/2" MDF benchtops, which would have much more uniform properties, but they still move about 2 1/2% over the same humidity range.
(Data at http://www.pbmdf.com/cpa30/files/ccLibr ... bility.pdf)
If you really wanted to isolate the lathe, it seems like it should be on a 3 point support. Or is there some sort of a middle ground? I have a crowded shop and really need to move the tools around as I work on different projects. I've been considering a square tube or wide c channel sub-base with 3 point support on a rolling cart.
I'd be interested in hearing what people with more experience would suggest. (this category probably includes everybody on this board)
wsippola
Re: Installation techniques for a benchtop lathe
Post by wsippola » Sat Jan 21, 2012 4:32 pm
You're correct of course that a wooden bench will move, which makes levelling it somewhat futile. I suspect a lot of benchtop lathes are nowhere near level, and depending on their design and size, it may not be any real problem.
You don't need a precision level, you can center the tailstock and then tweek the mount to get the best results, which is the primary reason for levelling. Hard to do if the tailstock ways are worn. Search for "Rollies Dad's" method if you want details.
Wayne
samthedog
Post by samthedog » Wed Jan 25, 2012 7:22 am
How much precision do you need? Considering that it is a bench top lathe I would think that rigidity would be a bigger concern when looking at accuracy than thermal expansion of the wood. If you want to increased rigidity compared to that of wood and decrease the thermal expansion, why not pour a concrete slab and mount that on a steel frame. If the air is a consistent temperature over the shop, you should have very little variation in the expansion rates of all the legs and therefore even if the legs expand or contract, they will do this uniformly. The concrete will add mass once the lathe is bolted down and this will reduce vibration. Just a thought...
Paul.
Speak with the circus owner instead of arguing with the monkeys.
hammermill
Post by hammermill » Wed Jan 25, 2012 11:20 am
adding a concrete bench top will deffiently improve thing on a small lathe. the mass alone dampen lots of vibration and add stability.
consider the main purpose of leveling is to get everything in a consistant plane. otherwise shipboard work would be inpossible, would it not?
Falcon67
Post by Falcon67 » Fri Jan 27, 2012 2:15 pm
I don't have any special precision issues using this $399 lathe mount:
I modify transmission fittings for race transmissions and can easy hold +/- .001. The head stock is bolted fairly snug and the tail end is just snug. Use bolts, washers and nylock nuts to keep things in place. Easy to move around and everything machine related is in the cabinet. If I got real concerned about the wood top moving around, I'd sheet the lathe end with 1/4" steel plate.
Chris -
http://raceabilene.com/kelly/hotrod
"Check all parts for proper condition before operation; if normal safety precautions are noticed carefully, this machine can provide you withstanding of accurate service."
stevec
Post by stevec » Fri Jan 27, 2012 6:25 pm
Show off!:wink:
John Hill
Post by John Hill » Fri Jan 27, 2012 11:34 pm
My 12x36 lathe before fixing down to my concrete bench.
IMGP9332 by aardvark_akubra, on Flickr
Falcon67
Post by Falcon67 » Sat Jan 28, 2012 11:22 am
stevec wrote:Show off!:wink:
8)
Chris -
JohnAspinall
Post by JohnAspinall » Wed Feb 01, 2012 2:35 pm
Wheels17 wrote: If you really wanted to isolate the lathe, it seems like it should be on a 3 point support. Or is there some sort of a middle ground? I have a crowded shop and really need to move the tools around as I work on different projects. I've been considering a square tube or wide c channel sub-base with 3 point support on a rolling cart.
I certainly don't claim much experience, but for what it's worth, I went the C-channel route, and (so far) have no complaints.
Pic here: http://www.chaski.org/homemachinist/vie ... 26#p178126
SteveHGraham
Post by SteveHGraham » Wed Feb 01, 2012 11:06 pm
It can be very hard determining whether the people giving you advice are painstaking craftsmen or just anal-retentive. This has been a big challenge for me. Don't get too caught up in setting the lathe up perfectly, until you see what it can do.
