I rolled the dice...
This is a powerful unit. Super nice arc, and easy to setup. It will even spray-arc. (Not that it's designed to) Way more powerful then a Hobard 210 or Miller Passport. Runs Co2 gas as nice as the passport, with a bit of fiddling with it. C-25 it weld way nicer then any Passport I have used..
I will say the Drive motor is a lot stronger on it then the the HH-210 of Passport. Would not take much for that. The only thing I have not found out is how it will run on my Thermal-arc scout welding generator.(PFC should help with that) Undersized but that machine impresses me on both welding, and the generator side. Got a plug coming to make it a direct hook up. The Esab is truly a 26 pound unit. 36 with a ten pound roll of wire. The power of this thing is great! The gun angle is not as bad as I thought it would be, and the plastic housing for the wire drive is a non-issue. Feeds well if you setup like the manual say too. It has a no drag adjust spool setup,and it seems to work fine.
Qset is easy to use, and handy because it's saves your settings when you switch out of it. Then just like any other mig to use, although there is inductance, and a slope setting for further adjustments. $850.00 shipping on-line was a really good price.
http://www.weldersupply.com/productdeta ... 74&pID=458 I was thinking of getting a Thermal-arc 181i, but I already have a 161s stick machine that's 120/240 volts. Also enough multi-process stuff that is close to the same weight, but over double the power. Mig only is cool with me.. both machines are way easier to carry being separate units..
I tried CO2 /C-25 /C-10 / and 98% argon-2% O2 Sprayed .030 with the last two gases. It ran out of steam on the C-10 around 433 ipm, but would handle max wfs with the O2 mix (473 ipm) Just kind of checking the output of this little guy. Not trying to really use it for that.
