The Home Machinist!
It is currently Sat May 25, 2013 4:27 am
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: Mill conversion
PostPosted: Tue Feb 07, 2012 12:51 pm
Offline
Has anyone out there converted a Wells Index mill with Bandit stepper motors to Mach 3 with new motor drivers ? I'm in the process of doing this and need some help in hooking up the limit switches etc.
LSGOD
Top
 Profile
 Post subject: Re: Mill conversion
PostPosted: Tue Feb 07, 2012 7:13 pm
Offline
There has been recent sentiment that knowing a user's location is important.
I agree, you really should update your profile to include your location.
Did you have specific questions about how/where to hook the switches, or ????
Top
 Profile
PostPosted: Wed Feb 08, 2012 11:49 pm
Offline
I wanted to find out if anyone had made this conversion and could supply me with any problems or wiring diagrams. I'm using Gecko drives and PMDX boards. I have the origional installation manual and schematics for the Bandit control.
LSGOD
Top
 Profile
PostPosted: Mon Feb 20, 2012 10:28 pm
Offline
Site Admin
LSGOD
If you are using MACH3 for the software, then read the manual. It will walk you through. Depending on your break out board and how many inputs you have, you can assign each axis limit switch to its own input or you can series all the limit switches together using Normally closed switches and use one input.
Marty
_________________
Top
 Profile
PostPosted: Sun Feb 26, 2012 4:30 pm
Offline
LSGOD
Marty
I am using MACH 3. I think I can use the limit switch wiring as is, on the Bandit.
LSGOD
Top
 Profile
Who is online
Search for:
Jump to:
