The Home Machinist!
It is currently Sat May 18, 2013 7:11 am
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2, 3, 4  Next
Author Message
 Post subject: Moving a Rockwell mill
PostPosted: Sat Mar 10, 2012 1:40 am
Offline
Looks like I've bought myself a Rockwell mill, and I need to move it tomorrow. I have to do it more or less by myself, or is this just too crazy. I just moved a SB 9A with a 4' bed, and it wasn't what I would call easy. If I have to get some help, then I will. But can I get it down into single parts, or anywhere close? I think we're talking 750 lbs or so, complete.
So I am guessing the head comes off easily enough.
Ditto the table from the saddle...
Now, can I (should I) try to remove the knee?
Now tha crazy part - will I (perhaps with help) be able to tip the column enough to un-bolt the the base? :mrgreen: I'm feeling healthily intimidated at this point. How much would the column w/ knee weigh?
If I do get the base off, can I get the column w/ knee onto a small dolly? (This has to go down a short flight of steps.)
How did you move your Rockwell?
BTW, it's in a small house, back room, wood floors, narrow passage to the front and down seven or eight concrete front steps. Yeah, lotsa fun :roll:
Help me out if you can!
thanks
Shaggy
Top
 Profile
PostPosted: Sat Mar 10, 2012 2:35 am
Offline
I'd just remove the head, round ram and handles.
Lower the knee all the way and have a go at it strapped to a hand truck with 2+ people.
_________________
Shop toys...
10X54" Vectrax GS20F mill with DRO & frequency drive (saved from the scrap pile).
Jet 13x40 lathe.
Powermatic 1150 drill press.
I love Craigslist!
Top
 Profile
PostPosted: Mon Mar 12, 2012 6:14 pm
Offline
My Rockwell Midi Mill came to me with 4 steel casters on the base. I used a Neighbors old ford tarctor bucket to strap it off. It rode atop two 4x4 stringers about 3 ft long for the short trip home, securely strapped with those cute flat belt ratchet straps of suitable Taiwam quality, and strapped to the corners of the Ranger bed. The post material was a wise idea, as we found rocing the mill on the casters put deep dents in the bed floor, from the pressure point. I moved it in one piece, it was loaded with a hoist slung from a pole barn cieling truss. We made similar moves with a portable engine hoist, rated one ton.
These things are clumsy, so plan and move slowly. Getting this thing swinging or dropped is very counterproductive.
The only mistake I made moving a machine was my 9 inch SB school lathe. We were being hurried by the former owner, and I forgot to lock the carraige and tailstock down. Upon lifting the bed up to unload it, the carriage moved and unbalanced the load, the carriage went downslope, whacked the tailstock, that left the bed and smashed the hansheel on the floor. Sooo, I ordered the correct handwheel blank and fitted it out for the tail, for about $17, as I recall. Unhappy, but unhurt, it was a small lesson.
_________________
Big Dave
Top
 Profile
PostPosted: Tue Mar 13, 2012 12:22 am
Offline
Congrats on a mill purchase Shaggy. I hope you got it home safely.
_________________
"...that they are endowed by their creator with certain unalienable rights,that among these are life,liberty and the pursuit of happiness." Thomas Jefferson
"When the people find that they can vote themselves money, that will herald the end of the republic." Ben Franklin
Top
 Profile
PostPosted: Tue Mar 13, 2012 2:09 am
Offline
Thanks guys. I spent nearly 5 hours dismantling and moving the mill on Sunday. The day before I'd moved a SB 9A out of the same house, so you might say it was a pretty strenuous weekend, but rewarding :D
The column turned out to weigh 'only' 200lbs. Several other bits are around 100lbs each, but all of it was manageable, blanketed and strapped to a regular appliance dolly. (BTW, total weight stated in the manual is 780lbs.)
The parts of both machines presently lie under tarps in the yard and strewn throughout my workshop, as I try to decide on the next move... Anybody got advice on removing a 50-year mix of sawdust, wood resin and oil varnish? :shock:
thanks again
Shaggy
Top
 Profile
PostPosted: Tue Mar 13, 2012 7:17 am
Offline
thanks again
Shaggy
Removing it from what?
Top
 Profile
PostPosted: Tue Mar 13, 2012 11:28 am
Offline
Yea Shaggy, are you talkin about cleaning up the machine tools you just got or are you planning on cleaning your shop :wink:
Seriously the last time I dragged a machine tool home I had to rearange everything I owned, but it was worthit :)
_________________
Top
 Profile
PostPosted: Tue Mar 13, 2012 11:46 am
Offline
stevec wrote:
thanks again
Shaggy
From where it's plastered all over the 'new' mill and lathe! 8>)
... and without removing the paintwork.
I've heard of using oven cleaner, but I think it might soften the paint. I will have to experiment
The previous owner did a lot of woodworking on these machines (musical instrument maker), and the residue is very resiny/gummy. In fact I had to crack the lathe feet off the bench with a pry bar 'cause they were so 'glued' down! It seems to be a hardened mixture of old oil and sawdust/resin.
I bought something called 'Super Clean', in a purple bottle, but I don't quite trust this new 'water-based'stuff. I've got a gallon of turpentine I might start with.
thanks
Shaggy
Top
 Profile
PostPosted: Tue Mar 13, 2012 11:48 am
Offline
My shop is beyond cleaning 8>)
Shaggy
Top
 Profile
PostPosted: Tue Mar 13, 2012 1:48 pm
Offline
Wonder if a steamer would get that off.
_________________
I like to think that I can see the negative in anything.
Top
 Profile
PostPosted: Tue Mar 13, 2012 2:59 pm
Offline
Guaranteed to remove paint.
Try soaking with mineral spirits (or Stoddard solvent).
_________________
Top
 Profile
PostPosted: Tue Mar 13, 2012 3:04 pm
Offline
Try Zep Citrus Cleaner in the trigger spray bottle.
_________________
Top
 Profile
Who is online
Users browsing this forum: No registered users and 2 guests
Search for:
Jump to:
