Drill Press Vise Mods
platypus20
Post by platypus20 » Fri Mar 23, 2012 11:01 pm
About 4-5 months ago I modified the drill press vises in the shop, to grip round items. Clamping down round items in a vise with flat jaws has been a joy, trying to hold it to drill, without it moving. I first saw this trick in my grandfather's machine shop in the late 60s and almost forgot about it, then in a flash of memory reboot, I remembered it and did all 3 vises in the shop.
I drilled a series of 3/16" hole in the top edge of the drill press vise, the holes with the use of taper pins allows the round item to be gripped securely. In the pictures I used a 4-1/2" x 1/4" grinding wheel to show how it works. The taper pins go down into the vise jaw face about 3/4".
1 - vise jaws drilled
2 - the pins close together
3 - the pins farther apart
4 - the vise and the taper pins
jack
Re: Drill Press Vise Mods
Post by Harold_V » Fri Mar 23, 2012 11:49 pm
Way cool! Very nice that the jaws become parallels, too.
Thanks for a very useful tip. I can see many readers reaping a benefit.
platypus20
Post by platypus20 » Sat Mar 24, 2012 9:21 am
Thanks, Harold
I was talking to a friend of mine this morning, he read the thread, he has made a set of jaws for his milling machine, now he is going to adapt this idea to those jaws, but the holes are going to be threaded. So he can use his clamping kit hardware.
jack
AlphaGeek
Post by AlphaGeek » Sat Mar 24, 2012 12:26 pm
That's pretty sweet. I've already made custom jaws for my drill press vise (huge improvement) and they'll be going on the mill to receive this modification today. I'll probably do threaded holes instead, as I can then use shoulder bolts of various lengths in place of the pins.
I also quite like the tooling plate mounted to the drill press table. Might have to give that a try as well...
-AG
Rule number one: Everything takes longer and costs more.
Post by Harold_V » Sat Mar 24, 2012 9:59 pm
platypus20 wrote:Thanks, Harold
In keeping with that theme, I own two Kurt vises for my mills. Both have had the body of the fixed jaw drilled and tapped to ccept ¼"-20 screws. The tapped holes are located immediately behind the jaw insert. I use them, along with small shop built clamps, to restrain parallels, or to set stops when working on small pieces. They've proven to be one of the best things I have done to make a vise more user friendly.
