daved20319 wrote:
Glenn and JTiers, trepanning really isn't an option, the hole needs to be offset in the face of a cylindrical piece, which would mean setting it up in the 4 jaw chuck.
Dave
Dave I am not sure what you are trying to do, but here goes my thoughts.
If you are after a face groove that isn't to deep for something like an O ring groove. Then maybe your mill and a boring head will work for you. I have ground round 1/2" HSS blanks in short lengths to make a face grooving tool of the proper width of the groove and then using a boring head and a piece of scrap. Made a few test cut to adjust the groove diameter to size. Then got to the actual part and with the quill locked touched off and feed up with the knee to the proper depth. Works fine for hydraulic manifold blocks and such things and faster than a 4 jaw if you already have the tools ground up for several O ring sizes from previous jobs. Even used them in the lathe a few times with the Aloris style drop in holder that have the groove for boring bars.
Hope this is what you are looking for.
Richard W.
