Today's progress on truing up the flywheels.
I spent another day, this last weekend, up at Harold's place, with the assemble flywheels. After going over all the measurements, we have come to the conclusion that.
Both the sprocket shaft and the pinion shaft, are not perpendicular to their respective flywheels. The sprocket shaft is farther out than the pinion.
As per the factory manual they should be perpendicular within .003 at the outer edge of the flywheel. Once the main shaft is installed between the two flywheels, the assembly is put between centers, with indicators on each of the shafts, next to the flywheels, and are to be indicated in, to less than .001".
In its present state, I can get the pinion side to .0005 and the sprocket shaft to no less than .005. We believe in this condition the motor may not last very long. I have two options. One is to buy new flywheels, or fix mine. I have nothing to lose in trying to fix these, but time, yet I may learn a thing or two, while trying. So the challenge is on! With Harold's guidance I may actually stand a chance.
The first thing to do is to get the flywheels in a condition to be able to mount them, well enough to be indicated, reliably. We figured the best thing to start with were the outer rim faces. Getting them flat and parallel to to each other.
I have wanted to give scraping a try, and thinking that it is not a large area and can be cleaned up later even, a gave it a go.
Here are the pictures!
This was the worst side, so I started there, giving me more time for the learning curve.
In this picture is the second scraper I made,laying on the cleaned up part. It worked pretty well.
The surface plate, Prussian Blue, height gauge, and a rubber roller.
These pictures, are of the other flywheel, both sides. I have not done anything to these yet.
More to come.
