I believe you are right on the drive mechanics of the screw, and the unit is open on the bottom (top in the photo) which is why the gear just fell out when the lead screw was extracted. I have looked inside that gear with my old eyes, and with magnification and cannot see where any shearing took place, the metal is even and smooth, and the patina over the entire inside surface is the same.
Plus, if the gear was keyed on the shaft, oil holes would be unnecessary since you wouldn't need to oil a fixed gear on the shaft? You are totally correct in the diagrams not showing a key (or pin) implying there isn't one, but what would fix that gear on the shaft when you transfer drive from the forward to reverse bevel gear?
The holes are not threaded, and as I said previously, one hole was completely packed with old grease, while the other was clear of it, again implying something was in that hole. But if it was a pin, what kept it in the hole during shaft rotation since the bottom of the gearbox is open?
I've been trying to puzzle it out, could it have been a "T" shaped affair, a square key with a pin that floated in the hole? If that is the case, why the devil wouldn't something that odd be on the parts list?
Gaaaaaaaa!!!!!! This is driving me nuts! (wife always tells me "that's a pretty short drive")
Maybe I should put in a call to Clausing and see if they can shed some light on this one....just been putting that off since I hate being on hold for 30 minutes, which seems to be the norm every time I call them.
Thank you all again, John
