stevec wrote:
I found this on the link "Great for backlash, but there isn't adequate friction to keep the screw in place.
You would need to introduce friction, not so much to lock the handwheel, but to keep force on the table from moving the table.
Some sort of plastic block rubbing/gripping the shaft would be a good start; get a spring in the system to keep the friction consistent.
If you can't figure out a way to introduce friction, don't install the ballscrew. "
I went further and found supporting posts. I didn't find the "Opposition to ball screws seems to be more theoretical than experience based" post but I'll let this go due to no personnal experience at all.
They had several people from both sides sounding off. This quote was in post #11 and the guy teaches in a school and has students running the machines with no problem. The quote isn't high lighted in the post, but is written in the first part of the post.
It reminds me of an old timer who told me gear head lathes were dangerous and you got gear marks in your finish. Yet there was nothing wrong with changing speeds on a line shaft drive lathe with the spindle running and moving the belts by hand from one speed to the next.
Richard W.
