Bill Wilkins wrote:
Take the air cleaner off so you can choke it with the flat of your hand or thumb. Run it wide open, choke it untill it slows to about half the RPM, un choke it, let it rev up to full speed, choke it again, do this three or four times leaving the throttle wide open all the time. This causes the engine to suck fuel thru the carb big time. Used to do this all the time to single throat Chevy's, Ford's, etc. Sometimes that was all it took. Gees, I may have dated myself.
Bill W.
Yup. Those engines were very forgiving. There is a story I could tell about a Model A Ford than ran with the idle jet bouncing around in the intake. The only reason it was discovered is that the engine would sometimes run terribly and then mysteriously run OK. But that was because said jet got stuck in an intake valve and held it open, and then would fall out leaving the valve to work normally, only to get sucked in again! With those engines, I think you could put gas in a spritzer bottle feed 'em by hand.
Makes me pine for the days of carburetors and breaker point ignition, when true jalopies could be had and run. They were cheap to buy and easy to fix. Lots of fun. How we kept from killing ourselves I have no idea. Today, you can't work on 'em because of the electronics and you can't run the beaters because they won't pass smog. Sigh.
