The Home Machinist!
It is currently Wed May 22, 2013 5:02 am
Post new topic Reply to topic  [ 9 posts ]
Author Message
 Post subject: $1.99 Track Cutter
PostPosted: Wed May 16, 2012 9:16 pm
Offline
Well, not exactly $1.99, possibly less, if everything from the scrap box is considered free.
I needed to taper some 1 3/4" square bar for some forks I am making for a friend's tractor. For a right angle cut, there are multiple options, but not for a 16" long bevel, and I did not want to do it on a milling machine.
So, two pieces of conduit, some scraps of unitstrut and clamps for the track, some allthread and a cordless drill for motive power, and a simple carriage running on old ball bearings with a few simple adjustments with a holder for a regular torch. I set the tip size and gas pressure per the Victor book and it worked great. Not the last time it gets used, I am sure.
Some of the large lumps are weights to improve stability.
Top
 Profile
 Post subject: Re: $1.99 Track Cutter
PostPosted: Thu May 17, 2012 1:40 am
Offline
Way cool, Russ! The poor man's track cutter.
_________________
Top
 Profile
PostPosted: Thu May 17, 2012 6:44 pm
Offline
I love it, the only thing I can not see is what did you use on the bottom of the carriage to ride on the conduit.
Top
 Profile
PostPosted: Thu May 17, 2012 9:14 pm
Offline
Mike,
One side of the carriage has several small ball bearings mounted in a V pattern so that they track on the tube, the other side has some bearings that ride on the top of the tube. I have a box of surplus bearings, 3/16 id x 7/8 od. Good for projects like this. The tube in the center is the guide for the allthread.
The picture is a bottom view of the carriage if you haven't already guessed.
Top
 Profile
PostPosted: Thu May 17, 2012 9:19 pm
Offline
Back to back;
The next step is to weld some verticals on the forks. The forks are clamped back to back and the vertical piece is aligned then fixed with a temporary strut. A bit of preheat is applied before welding then a whole bunch of passes are made with 7018 rod. After it has cooled for a few hours, the clamps are released and the forks are straight. Much easier this way than trying to straighten a couple of bananas.
While it was cooling, the track cutter was cutting out some sides from 1/4" plate.
Top
 Profile
PostPosted: Wed Aug 08, 2012 5:08 am
Offline
Thanks Russ,
Very cool setup :wink:
Ken. :)
_________________
One must remember.
The best learning experiences come from
working with the older Masters.
Ken.
Top
 Profile
PostPosted: Mon Aug 20, 2012 7:21 pm
Offline
Russ, This is one of the best ideas I've seen for a while. I suck with a cutting torch, but sometimes there's not alternative. (Sitting here running my scrap inventory through my mind right now.) I see a new track cutter in my future. Thanks.
Chuck
Top
 Profile
PostPosted: Tue Aug 21, 2012 8:46 am
Offline
Russ Hanscom wrote:
One side of the carriage has several small ball bearings mounted in a V pattern so that they track on the tube...
What are the standoffs that hold the bolts that act as axles for the bearings? Are they off-the-shelf items or did you make them? I don't recall ever seeing anything similar.
_________________
Ed
Atlas 618 lathe
US-Burke Millrite MVI mill
Files, snips and cold chisels
Top
 Profile
PostPosted: Tue Aug 21, 2012 5:13 pm
Offline
Those eyebolts happen to be surplus from long ago. You can accomplish the same intent by using short sections of small angle or turning the standoffs from 5/8" or similar stock. Depends on what is in your scrap box!
Top
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
