If some one here has a Forrester D/T fixture. I would appreciate info on bushing OD. Are they 5/16" OD?
I have a B-square fixture but they are now discontinued and bushings not available from them.
Thanx in advance..........pacrat
Info Needed
Re: Info Needed
are talking about the case legenth guage or??
Re: Info Needed
hammermill wrote:are talking about the case legenth guage or??
Nope..........I need to know the OD of the drill & tap bushings used with the Forrester scope and sight drilling fixture used to drill and tap holes in the reciever of rifles.
Re: Info Needed
ok i see what your after
http://www.forsterproducts.com/store.asp?pid=24833
didn,t see and external dims for the bushings at 500 bucks i would look at homebrewing one. could be a handy tool
to fill the out.3120 is the stock size for the inserts(thanks georgeg)
Re: Info Needed
The drill bushings are 5/16 od. I have both a Forester and a Billy Best drill jig. they are good jigs had the Forester since 1960. only cost 75.00 then. Paul
"a wise man learns by experience, a wiser man by the experience of others"
Re: Info Needed
Thanx for the info guys,
ordered a set of Forester bushings from Midway today.
Re: Info Needed
Further info. gleened from other forums.
All of the 4 popular drill fixture makers use the same 5/16".... .312 OD bushings. That is Forester, B-square, Wheeler, and the new one on the market Sun-Optics.
As of now Brownell's has them the cheapest at $19.95 for the set of 3.
Regular machinist suppliers such as MSC etc want half that for 1.
