HELP! I have a problem with SB ID, and getting the right com
steamin10
Post by steamin10 »
As the title says, I am having trouble getting the right compound and am now confused. The tag on the South Bend says it is a C model 42 inch bed. It has a single lever gear change box, and it measures about 5.5 inches from chuck center to lathe bed. The bed itself has a bunch of cast-in cross webbing below the ways, unlike my 9 inch that has just three cross bars. At any rate, some numbskull had a wreck and broke the back of the tool holder out leaving only the front side. I have since milled off the break and installed a bar to restore the tool slot, but being it is only held by two countersunk 5/16 grade 8 screws, I have little doubt it will fail early. I will cut a tool block to replace the lantern post for better strength, as the geometry should take some of the load off of the repair.
A compound bought off the internet will not fit the carriage, as the spud is too small. it seems to be 1 3/8, where the carriage is 1 5/8. Anybody have any greater knowledge here? Is this an old 11, heavy ten, 9 inch, or what?
I know, I need the serial #. Sorry, its at work, and I am home.
PS. Complete compound with small increment wheel for sale $80. Mine is good, I dont need it.
GlennW
Re: HELP! I have a problem with SB ID, and getting the right
Post by GlennW »
Would sleeving to spud to 1 5/8" solve your problem, or are there other mismatched features such as locking bolt holes?
wlw-19958
Post by wlw-19958 »
Hi There,
steamin10 wrote:As the title says, I am having trouble getting the right compound and am now confused. The tag on the South Bend says it is a C model 42 inch bed. It has a single lever gear change box, and it measures about 5.5 inches from chuck center to lathe bed. The bed itself has a bunch of cast-in cross webbing below the ways, unlike my 9 inch that has just three cross bars.
Do you have any pictures of this lathe?
Good Luck!
-Blue Chips-
Webb
steamin10
Post by steamin10 »
This is a sensative thing, as for pics, being its a company thing, and they are all suspicious. I have been given a nod to bring this small shop lathe up to a usable standard. I go to work tonite for two days and will try to get some sense of what I am dealing with. This shold have been easy, but as usual Murphy sneaked in. More later.
spro
Post by spro »
Hi Dave. I measured some stuff from an 11" S.B. (late '20's-early '30's) The compound doesn't use the tapered spud. There's a 3/8" pin in the center and T-nuts running in a machined ring of the cross slide. By the late '50's it looks as all sizes used the "spud".
hope this helps.
Patio
Post by Patio »
I have a 1945 SB Heavy 10 and the spud is 1 5/8 at the large end.
How large is the through hole in the spindle?
You may have a Heavy 10.
Live for the moment!
Prepare for tomorrow!
Forgive the past!
wlw-19958
Post by wlw-19958 »
Hi There,
Patio wrote:I have a 1945 SB Heavy 10 and the spud is 1 5/8 at the large end.
I've been thinking something along the same lines. Especially, when he said:
steamin10 wrote:The bed itself has a bunch of cast-in cross webbing below the ways, unlike my 9 inch that has just three cross bars.
That sounds like a late model Heavy Ten lathe bed. But the single lever QC
gearbox is indicative of an earlier Heavy Ten. I wonder if he is dealing with some
kind of "Frankenlathe." That is why I asked for a picture to help in identifying just
what kind of lathe he is dealing with.
Good Luck!
-Blue Chips-
Webb
spro
Post by spro »
Webb. I'm similarly confused. "The tag on the South Bend says it is a C model 42" bed.." By this later compound, models "C" were equipped with manual change gears, hence no shift lever. C also had a plain apron with no power feeds.
The heavy one( 1 1/16" collet capacity, 1 3/8 "spindle ID) wasn't even offered in a C model (1958 anyway).
steamin10
Post by steamin10 »
Sorry that I have given some small bits of info wrong. I have to make an effort to put hands on this lathe in the shop as it is out of the way sorta. It is a two lever change box, not one as stated, it is 1 5/8 carriage hole, and the carriage is equiped with a power feed apron for cross feed.
I did not get any pics. I was busy as all getout with down turn work, Sat-Sun.
So it appears it is a later Heavy Ten.
I butchered the broken slide and put countersunk 5/16 screws in some soft stock to redo the tool slot, but it is obviously weak.
I need the slide itself and the screw as some dolt mushroomed the threads for the dial nut. It has the large dial.
Richard_W
Post by Richard_W »
steamin10 wrote:
.....put countersunk 5/16 screws in some soft stock to redo the tool slot, but it is obviously weak.
I did this on a 24" swing German built Martin lathe, only I used 1/2" flat head screws. As far as I know it's still running in the Portland ship yard.
Richard W.
SteveM
Post by SteveM »
Dave,
This is a 9C:
This is a heavy 10:
Look at the apron to see the major identifying features.
Which does yours look like?
I'm with Webb - think it's going to be an H10
steamin10
Post by steamin10 »
Ya, thats the machine, only with a more modern cabinet, and it is an underdrive. One diference is a flip lever for the cross drive rather than the hand knob, an obvious addition.
I plsn on cutting a tool block, as it will work better than using the lantern post they have now, missing the rocker. These guys are cludges when it comes to lathe work.
