Also, whether there is a 5" or 6" riser under the turret.jcbrock wrote:It probably varies an inch or two depending on the motor.
Good Luck!
-Blue Chips-
Webb
You can also lower the quill to gain a little more room forjcbrock wrote:An additional consideration is the headroom to pull the drawbar if you need to, although you could rotate the head to the side to do that.
