Building a Power Model Water Pump
Moderators: Harold_V, cbrew
Re: Building a Power Model Water Pump
Postby Bill Shields » Tue Feb 19, 2013 1:05 pm
yes - doesn't have to be bronze - brass will work.
this is what I did with a porous casting
I didn't fool with locite for this, I just heated the casting and froze the sleeve and in it went.
John_S
Postby John_S » Tue Feb 19, 2013 6:00 pm
Fred_V wrote:why cast iron for the sleeve? why not bronze? would it work to Loctite it in?
Cost. You won't see the sleeve so it can be cast iron.
Have you seen how much a 6" long piece of 1.500" brass (or bronze) costs these days?
Stuie
Postby Stuie » Tue Feb 19, 2013 10:11 pm
Just make sure you store the locomotive with the pump dry! My dad spent an entire summer rebuilding his locomotive as a kid because the cast iron piston sleeves had rusted the piston in place. Even though he always blew the locomotive out with compressed air after each run, he made sure that he added extra oil from then on!
3/4" scale LBSC Bantam Cock
Projects
3/4" scale B4 (re-designed LBSC Juliet)
3/4" scale Southern/CNO&TP Ms-4
18 years old and loving the hobby!
- Stuart T. Harrod -
Postby Bill Shields » Wed Feb 20, 2013 7:20 am
exactly why I went with brass - pitting...
it is almost impossible to get these things dry.
John_S
Postby John_S » Wed Feb 20, 2013 6:50 pm
Few more parts finished up.
"Caps" as the print calls them -- basically keepers that fit into the water check passages in the cylinder:
I've got a piece of bronze material coming to make my steam cylinder sleeve out of. Until then... plenty more parts to make!
John_S
Postby John_S » Sun Feb 24, 2013 12:32 pm
Got the steam cylinder sleeve just about finished up this morning. The weather is so nice out I'm going to step outside for a bit and enjoy it!
Cast bronze, courtesy of Rich_D
Setup the cylinder in the 4-jaw and bored out an extra 0.9375"
Closeup of the steam passage that's the cause of all this extra work
Turning a mandrel to machine the sleeve on
Turning the ID of the bronze sleeve to match the mandrel
Turning the OD of the bronze sleeve with it mounted on the mandrel for a press fit into the cylinder
Cylinder and sleeve, ready to be pressed together
Pressing the sleeve in
Nearly finished. Last step is to put it back in the 4-jaw and bore the ID back out to 1.375" and then face off the extra sleeve material on the top end of the cylinder
John_S
Postby John_S » Mon Feb 25, 2013 8:08 pm
All better!
Pipescs
Postby Pipescs » Wed Dec 18, 2013 10:08 pm
curious as to what happened here.
Charlie Pipes
USMC Retired
Current Projects:
2.5 Baldwin 2-4-2/2-4-4/0-4-4 Conversion (What ever)
Little Engines American Restoration
Bobber Caboose
John_S
Postby John_S » Fri Dec 20, 2013 9:32 am
Pipescs wrote:curious as to what happened here.
Sidetracked with other projects, such as my scratch built hopper car :)
Hopper car for coal
The pump is still in progress and I'll be getting back to it soon. The last work I did was to make a mounting plate for the valve chest casting so I can set it up in any orientation and have it be square from any angle.
John_S
Postby John_S » Sun Jan 19, 2014 3:10 pm
Back on this project again... finished fixing my goof on the steam side of the pump from earlier (the hole that drifted). After sleeving the bore I drilled the passage (correctly!) from the opposite end, intersecting the previous hole.
Then machined the slot that connects the passage to the bottom end of the cylinder.
(sorry for the terrible photos -- I cannot locate my flash diffuser for my camera)
Next up I'll finish my fixture to hold the valve casting and start machining it.
Builder01
Postby Builder01 » Mon Jun 12, 2017 7:31 pm
Did you ever get your pump going?
David
John_S
Postby John_S » Wed Jun 14, 2017 8:56 pm
This darn thing is still sitting on the workbench unfinished. I really, really need to get back on it and get it on the mogul. The English injector I have on the fireman's side right now is pretty much useless and I need to get the pump done.
Married life, career change, and various other things have kept me from having my normal amount of shop time the last couple years. I've also been working on more urgent things than the pump. Perhaps once I finish the current project, replacing the Allen mogul loco brakes with equalized brakes, I'll get back on this.
Return to “Live Steam”
Who is online
Users browsing this forum: binnaway, daves1459, Yahoo [Bot] and 15 guests
