Hosed the keyboard
- Greg_Lewis
Hosed the keyboard
Just had to share this..... I was sitting in the dining room this morning reading the newspaper when I heard some discouraging words from my wife who was in our home office. Seems she dumped an entire glass of freshly squeezed, pulp-filled, orange juice into her keyboard. I grabbed the board, turned it upside down and dumped out most of the OJ but there was still some inside including bits of pulp. I took it out to the shop, pulled it apart and, figuring that we had nothing to lose, held the keyboard panel under the hose bib on the side of the barn and gave it a thorough rinsing. After washing out all the OJ, I blew the water out with an air nozzle and set it in the sun to dry. After reading this far, you have already figured out the end of the story. After reassembly, it works just fine. Some days you get lucky.
Re: Hosed the keyboard
A lot of people use the dish washer with the key side down with good results.
Richard W.
Richard W.
In the 50's and 60's detergent and water was the standard method of factory and field cleaning for Tectronix oscilloscopes, followed by a distilled water rinse and dry. Still works for a lot of electrical and electronic equipment.
Don Young
Good tips. I saved one I spilt too much whine into. No cleaning that.
Guy I worked with dropped his (brand-new, expensive) cell-phone into the drink. Yes, salt water. He had the sense to take out the battery as soon as he fished it out. Brought it to me the next day. I soaked it in a couple of changes of distilled water for a few minutes each, then put it in a drying cabinet (105F) and said "come back in three days". It worked too.
Pete in NJ
Here's another one for cell phones, PDAs, and such. As was noted, get the battery out fast as you can. Rinse in distilled water a time or two, dry it off with a towel. Then bury it in a bag of uncooked rice. The rice being dry, pulls all the moisture. I've seen this work several times. No, I never drowned my phone.......YET! I think this would work with a keyboard as well. Worth the price of rice.
Good Luck,
Terry
Good Luck,
Terry
- Greg_Lewis
I must add to my original post that the hosing turned out not to be flawless. This morning several keys stuck, but I popped them off and cleaned out the little holes they fit into and all is well now.
Hmmm! Makes me wonder if that's why some folks wash theirs with their dishwasher. Bound to get to every nook and cranny.Greg_Lewis wrote:I must add to my original post that the hosing turned out not to be flawless. This morning several keys stuck, but I popped them off and cleaned out the little holes they fit into and all is well now.
Good job, Greg!
I ran one of my first cellphones through with a load of laundry, left it in a shirt pocket...pulled the battery as soon as I found it, laid it on the baseboard heater for a couple days. I think it actually worked better after the wash job-I have a lot more respect for LG stuff after that...
go one step more and disassemble the keys. they are captive on most boards, so they won't all fall out. then you can clean them with lots of warm water and air dry. some of the contactors respond well to pink pearl erasers. just rub them to remove any oxide from them. i use this method and my keys never stickkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk. ha. ha.
atlas 618,MM challenger wire welder, 4x6 cheapo bandsaw, assorted junk, spears for hunting mastadons.
